Question about engine swap
Old Mar 29, 2009 | 11:36 PM
lorelei2009's Avatar
lorelei2009
Ok so I know most people swap for small to large but we want to go the opposite way. We would like to take out the 390 and go with a 300 6. Would we have to change any mounting brackets or anything like that. Basicly how much work is involved. My boyfriend would also like to put a 4spd in it cause he hates driving automatics. We like the truck but as a young family the fuel cost is hurting us but I don't want to part with it cause it would be hard to find another in this shape plus we know where to get a good 300 6 and a 4speed for it for a decent price.
Old Mar 30, 2009 | 02:25 AM
Alvin in AZ's Avatar
Alvin in AZ
The old clunker isn't going to get all that much better gas mileage with the
300 I-6. :/
The "perches" are the same between those two engines, but the rubber
mounts are different. The bell housing patterns are different too.
To switch to manual you'll need a pedal cluster assembly for inside the cab
and a clutch crank assembly that fits between the frame and the new bell
housing. You'll need a flywheel for the engine. The drive shaft situation is
different, manual transmissions have an external slip joint.
I see this stuff over and over here. :/ At least this time you are wanting to
switch to manual! LOL :) The trick is to buy a pickup like you want and swap
parts around and sell the pickup with the automatic.
If you've got a parts truck and are ready to go for it, it can be done. :)
You -can- do it. Betcha it'd be cheaper to buy one like you want tho! ;)
Alvin in AZ
ps- When all else is equal, pickups with automatics are cheaper to buy
because there are more of them and those wanting manuals will pay
more to get a manual. My usual argument don't fit here. ;)
pps- where you at? I have some of the parts you need and want a 390.
Old Mar 30, 2009 | 01:15 PM
lorelei2009
300 I-6. :/
switch to manual! LOL The trick is to buy a pickup like you want and swap
Alvin in AZ
Our truck has a 390 in it right now.
Here is a pic of our truck:
The reason we want to swap to the 300 6 with a 4spd is because we borrowed this truck once and it was alot better on fuel.
Link to Pic:
"BUILT TO 4X4" 1977 Ford F250 4x4 w/3" body lift
Although we may just be better off to buy the truck above if we can. Plus it's a 4x4 but it's also a shortbox and a bit on the highside for a 4 year to get in and out of lol.
We are on Vancouver Island in BC Canada
Old Mar 30, 2009 | 11:30 PM
4diggen5's Avatar
4diggen5
you will need a donor truck, that will be the cheapest route.
Old Mar 30, 2009 | 11:53 PM
Alvin in AZ
What's the rear axle ratio on the two pickups? :)
One of the main things threads about gas mileage need to have in them
is someone going off about how the person complaining needs to do a
thorough job on a tune up. LOL :)
Carburetor and choke adjustment and rebuild included.
Hardly ever does "main jet sizing" get mentioned either.
What's your tune up situation? :)
I like to check my ignition wires using an ohm meter.
Alvin in AZ
Old Apr 1, 2009 | 09:52 AM
4diggen5's Avatar
4diggen5
i have had all three engines and the 300 did get the best milage and was the most dependable but my 460 did about the same because of power to weight ratio i got about 14 mpg with 3:55 gears and 32 inch tires
Old Apr 1, 2009 | 10:01 AM
4diggen5's Avatar
4diggen5
the 351m did the worst of all as far as fuel mileage my 300 did the best on mileage but didn't have much power my 302 still not much power but the 460 had all the power you would want with just a couple of miles per gallon sacrifice.
Old Apr 1, 2009 | 12:30 PM
Alvin in AZ
Better gas milegae can sure enough be had after swapping to larger diameter tires. :)
What a guy needs to do to fully realize what the gain really is tho, is to figure
out using math and a road test (both) how far off the odometer is and figure
that difference in every time. It adds to the gas mielage when going to larger
tires and reduces the number when going to smaller than "stock" tires.
For years and years I was adding 12.8% because of my 235/85-16's up from
the original sorry little H78-15's. Since I changed the gears to 3.50 from 3.25
it's now only 4.7% difference.
Slide rules rule(!) in figuring proportion problems, if you got one, try it out. ;)
Alvin in AZ
ps- 12.5~13 on my 360FE T18 with a Comp "Economy" Cam at ~5080 lbs
