would like EVERYONES opion
ok this is my truck.
needs ball joints up/lower
needs 4x4 front axle work possibly hubs (still works)
needs a muffler(its not really loud but have to have one for state inspection the guy befour me just cut it off)
needs driver side window motor
needs ac compressor
needs tires (3)
needs tailgate
it has strait 6 300 4 speed with overdrive (runs good but shakes allittle and shifts fine)
167,000 miles
8 off road lights
has gun rack, cb radio, two batteries, grill guard
pretty clean interior
strait body has one bigger dent and a few smaller hardly noticable dents
alittle rust but nothing major at all
leaks allitle oil
ok his bronco
1979 351 winsor 4 barrel carb 4 speed transmission
runs petty good but motor shakes allitle
shifts fine but makes some noise driving down the road
4 new tires
needs front sway bar and maybe some other suspintion parts (shakes a lot when you jump on the brakes and when get going reall fast.)
4x4 works good new hubbs
pretty stait body no major dents paints allitle faded
didnt see any rust.
needs new carpet pretty dirty
needs some work on the blinkers
leaks some oil, transmissoin fluid, defferential fluids, power stearing fluid, nothing majoir
grill guard
he says it only has 34,000 original miles but i dont think that can be has to have at least 134,000 or 234,000
he said hed give me 400 dollars and the bronco for my truck i paid 2,000 for mine last month. if im gonna do it im gonna try to keep my offroad lights. does this seam like a good deal?
<!-- / message -->
**EDIT** 34000 miles and has tranny diff AND power steering leaks I CALL BLUFF! unles it was parked since 80 and the seals all dried up
i would probably trade for the bronco in your position you have a back-up vehicle to fall back on, not in need of the 150, and fan of the bronco. it sounds like its held together well and body frame and engine are known to hold up but before you do it you need to find out if the motor shake is a result of engine running rough or bigger internals issues.
