Towing 5th wheel
Old Jan 17, 2002 | 08:57 AM
bulabula's Avatar
bulabula
Post Towing 5th wheel
Old Feb 25, 2002 | 10:32 AM
LONEWOLF22's Avatar
LONEWOLF22
Towing 5th wheel
I have a 2000 f150 Supercrew, 5.4 v8, not sure of the rear end,
and a towing package. I'm considering upgrading from a pop up
camper to a 5th wheel with a dry weight of 6000 lbs. I've
calculated that about 1200 lbs would be added including passengers,
gas etc. I also have a short bed. What would you guys advise on
this configuration? Thanks for any help.
Old Feb 25, 2002 | 12:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Towing 5th wheel
I'd advise a bigger truck. You'll be at best at the very maximum that truck can handle.
To tow a fifth wheel with a SuperCrew and that VERY short bed you would need a special hitch. The only company that I know makes one is PullRite. Their website is www.pullrite.com.
Mark
Old Feb 25, 2002 | 03:01 PM
LONEWOLF22's Avatar
LONEWOLF22
Towing 5th wheel
Sorry, I didn't mean supercrew. I have just the extended cab.
Old Feb 26, 2002 | 07:50 AM
Mark Kovalsky
Towing 5th wheel
That's a little different. I'd recommend a bigger truck. The F150 is just not up to towing most 5th wheels.
At least if you keep this truck and have a long bed you won't need a special hitch. If you have a short bed you will need a sliding hitch to keep the trailer from hitting the cab on sharp turns.
Mark
