Blown head gasket?
Old Mar 29, 2009 | 09:46 PM
  #31
bfife's Avatar
bfife
still plays with trucks
Originally Posted by MADVAN
Test Tools Inc. - Block Chek
Napa test kit BK700-1006
Bill
Sold alot of those over the years. they really work well. not much money too
Barney
Old Mar 29, 2009 | 10:24 PM
  #32
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Tenn01PSD350
Never mind, I found what you are talking about. Hmmmm, cap tests good and excessive pressure. Back to where we were. Sorry.
Yep......
Old Mar 29, 2009 | 10:33 PM
  #33
jeff7825's Avatar
jeff7825
I was wondering the same thing. How hot is your coolant getting?
Originally Posted by cookie88
Hard to tell with the factory gauge. Not above halfway even driving home with an empty bottle.
That scan gauge that you have will monitor coolant temp i'm pretty sure.
Old Mar 29, 2009 | 10:46 PM
  #34
cookie88's Avatar
cookie88
FTE Emeritus
Possibly, but it's not of the parameters that comes up when I scroll through the list, and since it's not mine I'm hesitant to take it back through the set up menu.
Not really necessary anyway. I'll pull the thermostat out tomorrow, but at this point it seems unlikely that it will make a difference.
Old Mar 29, 2009 | 11:09 PM
  #35
Tenn01PSD350's Avatar
Tenn01PSD350
Unfortunately I agree. It's just what I would do too. I was just wondering if it was boost or simply RPM related. There is a very slight difference. CPs will be high in either case.
Old Mar 30, 2009 | 12:02 AM
  #36
cookie88's Avatar
cookie88
FTE Emeritus
I've held it pinned to the floor in the driveway and nothing. Has to be boost related. Doesn't do anything at all unless the engine is loaded.
Here's something interesting. I pulled the left valve cover just to look around....just for giggles I put a torquewrench on a couple of the headbolts and both of them moved before I hit 95 lbft. Now, the disclaimer to that is the only 1/2" drive wrench I currently have is an old craftsman deflection bar, so I don't know how accurate it is, but they moved by 80 indicated when the book calls for 95.....
So here's my new theory (one that was also suggested in an e-mail earlier). Suppose the gaskets are ok and the heads are lifting. That would explain why it's running perfectly...even when it's blowing coolant. Idles smooth and even, etc. etc.
Old Mar 30, 2009 | 01:16 AM
  #37
ron's power stroke's Avatar
ron's power stroke
it is possible for the head to lift and start leaking in high RPM's..I'm not sure pulling the T stat and running it is a good idea...doesn't the T stat send coolant to the back of the block?? it would be like putting the short t stat in wouldn't it?? how is the water pump??
Old Mar 30, 2009 | 09:01 AM
  #38
cookie88's Avatar
cookie88
FTE Emeritus
Yep. Forgot about that.
Today's plan is I'm going to go borrowa good torque wrench and retorque the heads and see what happens
Old Mar 30, 2009 | 09:33 AM
  #39
Kwikkordead's Avatar
Kwikkordead
Subscribing.
Old Mar 30, 2009 | 11:33 AM
  #40
strokersace's Avatar
strokersace
Hope you get it figured out Scott. I'm interested in your findings!
Old Mar 30, 2009 | 11:57 AM
  #41
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
also subscribing
Old Mar 30, 2009 | 01:34 PM
  #42
cookie88's Avatar
cookie88
FTE Emeritus
Ugh...what a waste this day has turned into. Took me half the morning to come up with an appropriate torque wrench, then I get home and start re torquing the head bolts only to come to the realization that the injectors have to come out to get to the top row of head bolts.
No now I'm going to have to get a set of o-rings just to complete the test.....and I keep reading threads that say "if it's blown it's blown" and I'll end up replacing the gaskets anyway......
I wonder if the injector o-rings are resilient enough to pop out and right back in?
So...I've a little over an hour before I have to leave for work. I think I'll just call this day a wash and hang it up.
Old Mar 30, 2009 | 05:27 PM
  #43
Automator's Avatar
Automator
Subscribing - Good Luck!
Old Mar 30, 2009 | 06:50 PM
  #44
beanhead6D5's Avatar
beanhead6D5
subscribing also!
Old Mar 30, 2009 | 08:07 PM
  #45
SuperDoodie's Avatar
SuperDoodie
Damn Cookie that sux! Wish I was closer and I'd lend a hand.. I have pulled heads before on mine took me less than 2 hrs to get the pass side off. I'm still skeptical you have a blown HG. Have you tried a leak down test yet? You could also do a compression test too. If you pull injectors, stick a bore scope down to see if there is coolant in the cylinder. I think you are chasing the wrong thing personally.
