Sponsored by: Real Truck
ticking 5.4
Old Mar 29, 2009 | 04:58 PM
suzuki0702's Avatar
suzuki0702
ticking 5.4
ive got a 2004 250 with the 2v 5.4 has approx 65k miles on her. ive noticed quite a loud ticking coming from the lower end of the engine. ive isolated it to where the trans connects to the crankshaft. it increases as rpms go up, not in noise just follows the rpms. im thinking that it all begun when i changed from penzoil full synthetic back to motorcraft syn blend. ?? any idears?
Old Mar 29, 2009 | 05:09 PM
ReAX's Avatar
ReAX
Are you sure it's not the Y-pipe? They put a new one on in 2000 or 2001, but mine flutters decently. A can of seafoam makes the noise worse, I think it breaks up some deposits that changes how the air flows.
You may want to look at your oil (either the dip stick or a short drain into a clean container) see if there are particles or crude that shouldn't be there.
spinella's Avatar
spinella
i don't know about the oil change, but if you isolated it to the crankshaft you might want to do a visual check on your flywheel for cracks or torque converter bolts(if its an auto) for being loose.
Old Mar 29, 2009 | 05:10 PM
Fordfanatic4life's Avatar
Fordfanatic4life
sure its not a exhaust leak ???
maybe one of the rearward exhaust manifold studs has broken off...have u scanned the exhaust studs to be sure they are all still present and tight ?
Old Mar 29, 2009 | 05:11 PM
spinella's Avatar
spinella
or what reAX said.
Old Mar 29, 2009 | 06:03 PM
suzuki0702's Avatar
suzuki0702
oils looked good i do all my own changes around 4k. i think that one of the studs is broken on the rear right manifold but i didnt think it would make that kinda sound in that area. maybe i should pull the inspection plate and peek after all.?
Old Mar 31, 2009 | 07:32 AM
browntown3's Avatar
browntown3
Mine started making a ticking sound that sounded like an exhaust manifold leak so i wasnt too worried.......but.........turned out to be one of my spark plugs blowing out of the head. I would definaltely recommend checking your plugs asap. Mine sounded like that for about 2 days up until mine blew out. Just from my experience.
Old Apr 19, 2009 | 04:57 PM
suzuki0702's Avatar
suzuki0702
well all checked out on the tc and the flywheel no cracks, no loose bolts. this is really starting to get to me! if it wasnt worth less than what i owe id trade the damn thing in!!! somebody help or to the stealer we go!
Old Apr 19, 2009 | 05:07 PM
Furian's Avatar
Furian
You Keep What You Kill
Did you replace the broken exhaust manifold stud (maybe gasket too) and check your spark plugs as recommended? If not, then I would start there before going to the dealership.
Old Apr 20, 2009 | 06:34 AM
suzuki0702's Avatar
suzuki0702
no all studs are present and ill check the plugs but noise is coming from where trans meets engine. thanks for advise fellas!
Old Apr 20, 2009 | 04:39 PM
83renegade's Avatar
83renegade
I've had mine in 3 different shops including the local dealership. 2 of the 3 couldn't find anything wrong. 1 said I have metal shavings in the oil and needed a motor. I now have it at another shop and haven't heard anything yet. When I dropped it off he said it sounded like an exhaust leak. Good luck. Please update when you find out anything.
Old Apr 20, 2009 | 05:01 PM
SuperDutyScaler's Avatar
SuperDutyScaler
my 04 was doing the same thing but i thought it was a blown header gasket turned out that the two bolts that hold the header to the y-pipe were a little loose. not enough to see carbon or black soot coming out but just enough to hear the ticking sound. tightened them up and the noise went away.
Old Apr 20, 2009 | 05:05 PM
LSAtexan4x4's Avatar
LSAtexan4x4
well how would you go about fixing the problem if it were a plug....... i have the same problem and it is annoying.......
