Adding Intermittant Wipers
Old 03-28-2009, 06:40 PM
79F150400M's Avatar
79F150400M
79F150400M is offline
Question Adding Intermittant Wipers
Been wondering about this for awhile now. I'd like to have delay wipers. Can I
change the switch or do I have to change the wiper motor too?? Prolly a silly question, but I haven't see this one on the boards for days. If I can swap switches, is it plug n play??
Old 03-28-2009, 06:54 PM
garypettengill's Avatar
garypettengill
garypettengill is offline
You need the correct switch and the black boelectronic controller) that mounts on the inside of the dash. It is a plug and play with these 2 parts. If you're junk yarding parts keep an eye on the late 70's and early 80's vans also, they use the same system.
Old 03-28-2009, 07:17 PM
1977f250's Avatar
1977f250
1977f250 is offline
Yes you can and it is mostly plug and play. You can go to the junk yard and get one for a 79 if you fell lucky or do like I did. I carry a pair of pliers in my pocket to check the switches as most I have seen people take the ***** off to get the dash bezel off. Turn the **** to find off. or use the pliers to turn it. To the right you have low and high. Turn back to off and will it turn to the left? if so you have found want you need. Take the switch out and you will have the switch and a short loom to the black box then the plug. It is the black box it what you need. Take it all as I don't think it comes apart. Look for a mid 80s F150 seems like most of the ones I have seen have intermittent wipers . Pull you switch out and you will notice that is two plugs into the switch. Plug the larger one with 5 or 6 wires into the new plug. If I remember right it will only go in one way. The smaller plug 2 wires (If I remember right) it has the squint pump wire (black with green tracer), plug it in backwards (it will do this) and will work fine. The only difference is that the shaft for the **** will be about 1/4" longer and you can cut it down and grind the flat spot on it or do like I did and just leave it that way. I learned this on this board and I still think it is the coolest thing I ever did to my truck for 3 bucks. I look all the time I go to the yards and yes about 6 months later I found one for a 77 but I still have the 85 one in mine, just put the 77 on the shelf. This will also work on a Jeep CJ with the 4 wire motor.
Old 03-28-2009, 07:30 PM
Fordworth's Avatar
Fordworth
Fordworth is offline
I took mine from an 89 or 90. Like Gary said, you just need the switch and the black box. The box has 2 pigtails, one plugs into the switch and the other into the truck harness. It really is that easy. The hardest part is mounting the black box. I used a sheet metal screw through the wall above the kick panel, took about a minute. BTW, the switch I got works like this - delay settings to the left, off in the center, and low/high to the right. It took disasembling it for my dumb *** to figure it out.
Old 03-28-2009, 09:43 PM
Customcab's Avatar
Customcab
Customcab is offline
Delay wipers in my opinion is more important than power steering options. But I always forget to check for this option in the junk yards. Thanks for posting this thread; hopefully I will upgrade my trucks.
Mitch
Old 03-28-2009, 10:06 PM
bareaneye's Avatar
bareaneye
bareaneye is offline
The intermittant box will work off many vehicles in my experience. The boxes of early
70's into the late 80's have worked for me. As long as it plugs in it has worked for me.
Old 03-29-2009, 02:13 AM
m j's Avatar
m j
m j is offline
there was one wire different on the switch on mine, the windshield washer gets power from a different post
Old 03-29-2009, 09:43 AM
1977f250's Avatar
1977f250
1977f250 is offline
" there was one wire different on the switch on mine, the windshield washer gets power from a different post"
The small plug (two wires) plug it in backwards and your good to go
Old 03-29-2009, 12:37 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
The Wiper Switch in the Econolines is a slide switch and are different and will not work.
Wiper Switch Part #: D3AZ17A553D Motorcraft #: SW1155A / For use with intermittant wipers. Fits E-Series Vans. 1975-1991
The Wiper switch in the F-series is a rotary type. Part number #: D1OZ17A553A Motorcraft #: SW1010 / intermittant wiper switch / Fits 1973-1979 F-series. OBSOLETE.
Old 03-29-2009, 02:22 PM
jb10's Avatar
jb10
jb10 is offline
saw one on ebay just yesterday
Old 03-29-2009, 03:34 PM
Don S.'s Avatar
Don S.
Don S. is offline
Good stuff here, I was just thinking about this last week driving the truck it was rain/mist and it was driving me nuts. Enough rain to justify hitting the wipers, just not enough to have them running the full time as the wiper would screech across the windshield.
Old 03-29-2009, 06:04 PM
Tees77f150's Avatar
Tees77f150
Tees77f150 is offline
COOL! I got to get this up grade for my 77, it would be SWEET!! thanks for the information guys, I am going to be looking for sure!
Old 03-29-2009, 06:17 PM
1977f250's Avatar
1977f250
1977f250 is offline
JB 10 ( I got mine from the pull and save on 33 just west of peroa in Aurora) I dont know what ebay gets but I paid 3 bucks from a junk yard for both of the ones I got. I would think you gould get one for no more that 5 bucks
Old 03-30-2009, 12:14 PM
79F150400M's Avatar
79F150400M
Oh jeez...look what I started!! But its all good. Lots of info that I didn't know. Thanks to all who chimed in. I knew about the switches, but not the black box. Pull-A-Part here I come!!! (this sounds real easy)
Old 04-01-2009, 08:12 AM
wasa 1500's Avatar
wasa 1500
wasa 1500 is offline
Thanks, I was going to ask this am! Misting rain drives me nuts also.
Quick Reply: Adding Intermittant Wipers
