2002 f350
2002 f350
Got my first diesel fixer upper. 2002 f350 4x4. Quick background-truck had no starter on it n fuse box had a burnt spot on the back behind starter relay I put starter on n replaced fuse box. Got two fresh batteries in it. When I turn the key the abs light n airbag light pop up but I have nothing else. Truck won’t try to start, no radio, windows, lights or anything
This vehicle doesn't have a GEM module, so that cannot be it,
You have a "NO POWER" problem, at least in the areas where it's needed to fire up the instrument cluster and the rest of the non-operative sub-systems.
I'd be looking at that replacement fuse box and all its connections with a VERY skeptical eye. I'd suggest starting by inventorying EVERYTHING electrical that does and does not work correctly. Post that list and we'll be better able to point you in the right direction without wasting a lot of time checking unneeded items.
update. I’m lost. I have power to fuse box. Rechecked all plugs n connections. Power door locks are the only thing that work. I tested ignition(good). Tested ignition actuator (good). Rechecked every fuse n relay with meter. All checked good. I’m thinking maybe computer? Any help Is appreciated
Racheljune
05-26-2013 12:48 PM
unclelee
16
10-29-2012 06:31 PM
