need info
Old Mar 28, 2009 | 02:24 PM
str8racing's Avatar
str8racing
need info
Need help door lock accuators, you can hear them clicking but do not lock doors, how to repair? 95 f150 5.0
Old Mar 29, 2009 | 01:33 PM
LynnL's Avatar
LynnL
Pull door panel (6 or 7 screws, 8mm screw for door handle if you wanna pull it)
Undo clips on door handle rod and lock rod (you can get replacements at most parts stores if you break'm, I usually keep some on hand)
undo latch from door and you should be able to see how everythings attatched. Basically pretty simple.
Oh, and be careful with the moisture barrier (plastic between door panel and door), you can use duct tape to put it back on if you need to.
Mr. Hatt
Feb 15, 2010 03:37 PM
RVXLT
1983 - 2012 Ranger & B-Series
Dec 13, 2009 02:38 PM
Corona Freak
New Member Introductions
Jan 24, 2008 07:47 PM
glk
Jun 14, 2004 02:51 PM
