Recharge RV battery
Old May 1, 2002 | 06:39 AM
gochay's Avatar
gochay
Recharge RV battery
Where do i connect the black wire (at the one o'clock on the receiver of the 7 pin connector) on a F150 2000 Lariet. The two relays are installed in the relay panel...I have located the blue wire under the truck which has voltage but it has the blue wire from the receiver connected to it. My question is where do i connect the black wire on the receiver to the truck which will allow my RV battery to recharge while the truck is running...thanks
Old May 1, 2002 | 11:38 AM
CmprSpecial's Avatar
CmprSpecial
Recharge RV battery
Check here, http://www.rverscorner.com/wiring/four.htm
Old May 1, 2002 | 01:46 PM
CmprSpecial
Recharge RV battery
Got your email but I do not know how to respond.
According to the chart at the link I out into the previous post the black wire at 2:00 o'clock on the truck and 10:00 o'clock on the trailer should go to battery positive on the truck. You may want to consider adding an isolator to the circuit if you plan on leaving the trailer hooked to the truck for extended periods so the trailer will not drain the battery in the truck.
Old May 2, 2002 | 02:10 PM
harryball's Avatar
harryball
Recharge RV battery
