No Start, No Click No nothing!!
My batteries arent the best, but it also happens with a charger on and/or boosting it. I havent been driving it much cause I dont want to get stranded when it doesnt start!
I can go out to the truck and crank it slow with a boost cause the batteries are weak. When I give it a few minutes to charge and go to start it again, it wont crank, wont click or anything. I know I have good power because the clock keeps the time, interior lights are bright, heater works good.
Is there a relay that might be getting stuck?
Once I start driving it regular, the batteries hold up. I dont want to start throwing parts at it unless I know what Im looking for.
Thanks
Running the clock and some accessories will only draw a relatively small amount of current compared to the requirements of the trucks Starter.
By not driving the vehicle and/or very limited use, or idiling is not sufficient enough to keep the batteries up to par. Also the possible inconsistant over or under charging.
Once a battery is fully or partialy discharged a few times it's life fades quickly and starting becomes difficult, especially with your PSD.
The fact that you live in the cold makes a huge difference as well. Batteries hate the cold.
I would suggest if you don't use the vehicle much but need it for security i would purchase new batteries to start with (no pun intended). I would suggest a name brand that you can purchase locally that offers free replacements. Some of these like the MAX+ (avail. at Walmart) have a 3 yr. replacement warranty.
Make sure you clean all your terminals on the cable ends. This can even make a big difference on the system you currently have.
I would then suggest purchasing a charger with low/conditioned charging rates. here is a site you can get some ideas on. 12v Smart Battery Chargers | 12 Volt Gel Cell & Solar Batteries | BatteryStuff.com
Thanks
When you start the truck your IDM needs to see a minimum of 10.5 volts to fire the injectors. This is one reason why good batteries are important.
If you are running dino oil and it is cold this adds to the "drag" on the starter. More resistance = starter drawing more voltage from the batteries. I changed to Syn and have not regretted it at all.
Change out both batteries and make sure ll the connections are clean and not corroded. Check the grounds on the block, and the jumper to the chassis as well. Take a look at the wiring on the starter make sure that it is not corroded and is clean and tight.
We have seen where people have run their batteries down to low and it has taken the alt out with it.
