Offroad & 4x4
Ideal suspension
Old Mar 27, 2009 | 08:48 PM
wlittle's Avatar
wlittle
Ideal suspension
I was wondering if anyone had any idea as to what would the best suspension setup for a daily driver, occasional trail truck. I would like to build my own frame out of 5 x 2.5 tubing. I have experience in fabrication and welding so am not worried about the work. I just do not know if coil springs, leaf springs or a 4 link would be better. I am not rich, but looking for something a little different. My project is a 1979 ford f-150 extended cab. I would obviously like the cheaper route, but do not want to redo it in a few years. Any ideas
Old Mar 27, 2009 | 09:01 PM
oldirtytruck's Avatar
oldirtytruck
I would say. Start off simple with the leaf springs and work your way up to coil over with 4link. I've seen 4 link done on leaf springs and it looked ok. Leaf springs have some flex, but not a whole lot. In the same breath, depending on how you set your leaf springs up they could have a lot of flex.
What kind of trails you plan on taking the truck on? If it includes lots of rocks, I would say stick to coil overs. I haven't work much with coil over so this is my opinion from seeing and reading others experiences. Leaf springs is pretty much all I have ran with. Cheaper and simple.
Old Mar 27, 2009 | 10:27 PM
wlittle's Avatar
wlittle
I would just like to take the truck off-road on a few trails, nothing to crazy, just something to take the family out. I thought about coil springs, but wondered how much weight they could handle. I also thought leaf springs would be all around the best choice for the money, and will probably go that route. 4-link sounds cool, but wonder if it is worth the time and money. A lot of the trucks around here run 6 inch lift and 35 tires, so I want something different again, maybe 37 - 40 inch. I am really wanting something different than anyone else, and will listen to any ideas.
Old Mar 28, 2009 | 08:07 AM
teds74ford's Avatar
teds74ford
Coils can handle just about any weight. Lots of 2wd 1.5 ton trucks had front coils. That being said, I would just do leaves and base it on something common and easily upgradable, such as superduty or 73-87 chevy springs. If you want to get truly creative, research building custom leaf packs. Some guys swap in rear springs in the front from a K5 blazer. There's tons of ideas out there.
I am building a 68 Dodge crewcab for this exact same type of use. I built the suspension based on stock springs. This way I can buy an off the shelf lift kit for it if I want it higher later.
Old Mar 28, 2009 | 08:05 PM
oldirtytruck
( www.DIY4X.com)
This web site under suspension has an adjustable mounting kit for placing 52' rear chevy leafs on the front of your rig. They advertise for chevy but I'm sure there's a way to bolt or weild it to any type of truck.
txbest1980
1997 - 2003 F150
38
Aug 13, 2015 10:04 AM
Speedjester
Jan 21, 2015 02:52 PM
blick
16
Jul 2, 2014 12:00 PM
MrKen
Aerostar
Mar 12, 2013 04:00 PM
makthenif
Nov 21, 2011 02:48 PM
