Stuck Distribator
Old Mar 27, 2009 | 05:52 PM
61ford4u's Avatar
61ford4u
Stuck Distribator
Has anyone ever came across a distibator that just wouldn't break free?I have been trying to get this thing free to set timing and it just wont move. Its a 400 out of a Lincoln I put it in my 61 Uni. It started popping through the carb so i thought i would check the timing and it wont budge.So i though i would take it completely out and it is stuck in there real good. Any help would be app.
Old Mar 27, 2009 | 08:42 PM
Shorty 66's Avatar
Shorty 66
Try some penetrating oil. If that doesn't work you might have to use a plastic or rubber hammer and try to brake it free. If not break it.
Old Mar 28, 2009 | 02:37 AM
camperspecial65's Avatar
camperspecial65
penetrating oil is the trick...try PB Blaster...or possibly a lil bit of diesel to clean the area on the manifold/dizzy mounting area...after its all cleaned up(pull off the lockdown plate totally...but put bolt back in hole tight) put a bit of diesel around the dizzy and see if it seeps down...rememeber theres 2 surfaces that it slides into...the lower one in the block is the main culprit as far as it sticking goes...
Let it soak a bit and keep trying to knock it loose...if its a 'common' dizzy and easily and cheaply replaced you may wanna have a replacement handy...just in case...
As for it running and needing timing adjustment..the timing set may just be needing replacement also...just something to keep in mind...
- cs65
Old Mar 28, 2009 | 04:49 AM
lew52's Avatar
lew52
All of the above & try tapping it with a long punch at the base of the dizzy..This works most of the time...Lew
Old Mar 28, 2009 | 09:28 AM
Redmanbob's Avatar
Redmanbob
You can make a basket like puller harness from some coat hangers and a use a dent puller with a j hook on the end. Watch out for your teeth
