Towing with the V6
Old Mar 31, 2002 | 03:16 PM
paulvanharte's Avatar
paulvanharte
Towing with the V6
I checked the forum, but I guess I am still unsure.
Currently have a 2001 Nissan Pathfinder 240 hp V6, I pull a 2900lbs travel trailer ( empty) plus two adults, two kids and one dog.
looking at a 1999 V6 auto F150. Dont have any detail on axle etc etc.
It does have a trailer hitch and wiring.
Will I be able to pull my trailer? Travel mostly here in Alberta ( Canada) and BC ( mountains).
Thanks for the info
Old Mar 31, 2002 | 04:20 PM
sportscar's Avatar
sportscar
Post Towing with the V6
[updated:LAST EDITED ON 31-Mar-02 AT 05:25 PM (EST)]I asuume you are looking at a SuperCab with the kids and a dog. I checked my copy of the 2001 Ford Towing Guide. In 2001 the only V6 auto S/C was a 4x2 with a 3.55 rear axle. Its listed at a max rating of 5,500lbs. So, based on this info, techincaly you would be ok with a 3000lbs trailer. But I think you would be much better with a V8. I sure the "board" will agree. Add in the wirght of the family, gear etc you will be getting close to the max wieght. The F150 is heaver to start with and I don't think the Ford V6 is as powerfull as the Nissan.
Old Mar 31, 2002 | 07:34 PM
paulvanharte
Towing with the V6
Yes I am looking at the super cab, or whatever its called.
I have no problems pulling the trailer with the Nissan which is rated at 5000 lbs. I try to travel without full water tank in trailer.
You are right the Nissan V6 is more powerfull than the Ford V6. Also the Nissan is much lighter. It is just getting to expensive and a truck would be perfect camping.
Old Mar 31, 2002 | 09:12 PM
4x4x4x4's Avatar
4x4x4x4
Towing with the V6
If you can find a V8 go for it.I don't believe the Ford V6 has the best reputation for long term durability.I believe it has it's roots in the Ford 3.8 V6 and it had head gasket problems.
Someone please correct me if I'm mistaken.
Old May 10, 2002 | 03:14 AM
Ford501's Avatar
Ford501
Towing with the V6
its better to spend abit more and go with the V8
you'll save a buck but
you'll regret it everyday untill you sell the truck
1995 XLT F150 4X4
E4OD 4" Lift 33" BFG ATs
Old May 10, 2002 | 08:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Towing with the V6
Dieselman1975
Mar 7, 2015 11:23 PM
brianedward69
New Member Introductions
Jan 15, 2015 01:23 PM
glenza
Jan 10, 2015 01:27 PM
hughjazz
Nov 20, 2014 10:35 AM
Soko179
Dec 10, 2013 05:12 PM
