firewall
Old Mar 27, 2009 | 11:17 AM
nflfreak43's Avatar
nflfreak43
firewall
i need to know the easiest way to bypass the firewall for a power wire for an amp. thanks to any help............
Old Mar 27, 2009 | 11:21 AM
darthice's Avatar
darthice
There should be rubber plugs located in the corners of the cab i ran my cb coax through one of them havent had a leakage problem yet
Old Mar 27, 2009 | 11:27 AM
nflfreak43's Avatar
nflfreak43
where? top? bottom? left? right?
Old Mar 27, 2009 | 01:18 PM
1966Tbird's Avatar
1966Tbird
you could run it through the boot where the steering passes through the firewall or drill a hole and put a gromett there
Old Mar 27, 2009 | 01:26 PM
bjafeman's Avatar
bjafeman
There's lots of space where the wiring harness comes through the cab/firewall (just behind pedals) and it's an easy to access space from the cab and the engine bay. Get a rubber grommet and drill away.
Old Mar 27, 2009 | 05:00 PM
nflfreak43's Avatar
nflfreak43
but wouldnt that have the chance of getting hung up on the steering?
Old Mar 27, 2009 | 05:07 PM
Fordzilla80's Avatar
Fordzilla80
Not if you can find a way to keep it away from the steering.
Old Mar 27, 2009 | 05:12 PM
nflfreak43's Avatar
nflfreak43
wait duh! i just remembered when the steering column goes through the firewall it has a little shield. so nvm. idk why i forgot bout that.
