HELP!!!! (rag bushing on 76)
Old Mar 26, 2009 | 10:06 PM
76rangerguy's Avatar
76rangerguy
Question HELP!!!! (rag bushing on 76)
Hi ya'll
I'm new to the Ford truck life and i need help. I'm trying to replace the rag bushing in the stearing line on my 76 ranger that i just bought. i thought it would be easy, but my lack of know how is kicking my a$$. I have taken the two bolts out that hold it together but i cant get the two shafts separated enough to take them apart so i can knock out the guide bolts. I have loosened the pinch bolt and the bolts mounting it to the firewall and the clamp before the firewall but to no avail. I feel like if i pry on it any more I'm going to break it. If you have any suggestions I would appreciate it enormously.
Thanks
Old Mar 27, 2009 | 04:12 PM
ohmyf150's Avatar
ohmyf150
Inside the truck, loosen or remove the two bolts that hold the steering column onto the bottom of the dash and pull the column out enough to give you the room you need. Change the rag joint then push the column back into place and bolt it back up.
Old Mar 27, 2009 | 04:22 PM
76rangerguy
Thumbs up thanks
thank you ohmyf150, i knew it would be something simple, i had every other bolt and nut off this thing and those were the two i missed. I appreciate your help.
Old Mar 27, 2009 | 05:16 PM
ohmyf150's Avatar
ohmyf150
Your welcome and good luck!
Old Mar 27, 2009 | 09:58 PM
Tees77f150's Avatar
Tees77f150
Hey ranger, don't forget to give ohmy some rep points, I know he will appriciate it!.
1983F1503004x4
Mar 5, 2013 11:57 AM
STGFordCrazy04
May 28, 2012 05:02 PM
FTWDEVIANT1
Offroad & 4x4
Feb 10, 2008 10:32 AM
tmcrew
Nov 27, 2004 09:40 AM
HiMe
28
Mar 6, 2001 05:46 PM
