General Automotive Discussion
Timing
Old Mar 21, 2002 | 11:28 AM
Shannonm1's Avatar
Shannonm1
Timing
Just wondering, how does retarding timing give more torque? I have seen this stated a few times. I thought advancing the timing gives more power.
Old Jun 4, 2002 | 01:47 PM
dpoelstra's Avatar
dpoelstra
Timing
advancing the timng improves all around performance. Retarding the timing will improve gas maileage, but reduce overall performance.
That is why on older trucks when you mash the pedal, the vacuum advance advances the timing for power, and when settled into your speed, raising the vacuum, the timing retards improving fuel efficiency.
When advancing the timing, the old hotrodders trick is to advance it until it will barely turn over when you start it, and then back it off just to get rid of the pinging. It works.
Old Jun 4, 2002 | 09:08 PM
Like M. Fords's Avatar
Like M. Fords
Timing
I don't think retarding gives you more torque as much at it allows you to put a heavier load on the engine without it pinging. Typically advancing will give an engine more efficiency and thus more power to a point depending on fuel type and compression ratio. In my '69 F250, more vacuum as well as higher RPM will advance the timing. When you mash the pedal, vacuum is lost and the ignition retards some to prevent pinging.
Old Jun 4, 2002 | 09:21 PM
Like M. Fords
Timing
Tnewton
Mar 8, 2016 05:13 PM
chiefsfootball
Mar 2, 2015 06:34 PM
lemasters f100
Oct 2, 2013 10:01 PM
fixnair
User Gallery & Picture Display
16
Dec 28, 2009 08:54 PM
