Also, will any LT headers bolt onto GT40 heads?
I am not sure what pushrods I am supposed to get either(6.875 in or 8.156in)... How would I figure this out? will i have to wait until I get the motor torn apart?
That is the correct timing set and rockers, make sure you get lifters with the cam, it should come as a set. You don't need pushrods the stock ones are fine. Externally the GT40 heads are the same as the E7's so any LT for a 5.8 truck will fit. Good luck.
