I have been having a problem like this but it's only when I first get going,once i have ran it it stops. But what mine does is it starts fine then when I get about a mile up the road it acts like it's running out of fuel and dies I then crank on it until it starts then go on my way? I hope somebody can help!
Check your oil levals ...I had the same thing like that about 8 months ago .......I'm imbarised to say I let my oil levals get to low and apperantly they also help run the injectors for the fuil ( or something like that ) , but it's a start............
So would a dirty air filter cause my truck to stall out ......it's been a while since I've replace my 6637 but I never thought that would affect anything that much ..........
I'mabout ready to trade the freaking thing in for a Jeep ............. But thats a different forum ....... LOL.
Naw, air filter will not cause a surge. I am dealing with the same prob on my '01. Going to take the tank off Tuesday at a buddies shop and look at that danged sock to see if it is plugged. I have heard that the low sulphur fuel will loosen all kinds of garbage in the tank (like running veggie oil) and it will plug up the sock. Hopefully, I can do the tank mods while it is off and get rid of Fords better idea of a long fill tube and those damn snap on fuel lines to boot. If that does not stop it, Ed has a great price on both of the sensors (one on the HPOP and the one on the head for $325.00. A lot cheaper than $480.00 at the stealership.
Your air filter would have to be very dirty to affect cause your problems. You would also have lots of dark smoke. Still, it's a good idea to keep a clean filter.
HPOP ?????? what the hells that ..well that hole proces sounds like a ton of fun...............and I don't even have $350 for parts like that right now .......I sure hope to hell it's not that .................... ...............trading this sucker in sounds better and better ..............
HPOP = High Pressure Oil Pump
And it's always cheaper to keep and fix what you have unless it is totaled.
HPOP ....wow that sounds like another fun job to do ...........
Yes but the headache is gone ............ Don't get me wrong ..I love my truck ......but I've had nothing but bad things happen with it since I bought it .............
OK...got My OBD II back from my dad ........I got a code P1298 wich is the Injector Driver Module failure ......... so as soo as I figure out what that is I'll fix it ...but I got another 3 codes to ..........P1509 ??? could'nt find it in the book .....any Idea's ................... P0113 and P0118 wich were generic for Intake Air Temerature Circuit High Input and Engine Coolant Temerature Circuit High Input ..........................................
So any Idea's .................... THX Guys
OK........sooooooooo I have not checked under the valves yet ...but I've been driving the truck with no problems last couple days .. ( knock on wood ) , thought I'd recheck the codes for some reason .......nothing poped up on the OBD ........so I started the truck ...let it run a bit and then rechecked ...still nothing..............Could this all been the part of bad fuil ???????? I keep running around in my truck hoping nothing goes wrong but wanting something to happen so I can diagnose this thing better ...and now with no codes showing I'm realy puzzled .........any new Idea's guys ...................THX FOR ALL THE HELp ....................C.
So I may just need to do the Fity Cent Mod ......... Edmonds is about 20 min North of Seattle ....so yes it is Coastal being Pugit Sound Area ............
