wiring dilema
Old May 31, 2002 | 04:32 PM
greghoffmann's Avatar
greghoffmann
wiring dilema
My trailer and truck were great. Then all of a sudden things got weird. The break light fuse and blinker fuse blow when the trailer is hooked up. Any ideas /
Also why do my flashers not work when the brake lights are on?
Everyhting was so good for a long time.
Old Jun 3, 2002 | 04:35 PM
whaynes's Avatar
whaynes
wiring dilema
Check all your ground wires....
Old Jun 4, 2002 | 08:11 AM
mitchntx's Avatar
mitchntx
wiring dilema
Grounding ...
I ground on the trailer (which travels through the hitch) and through the plug as well.
Old Jun 4, 2002 | 09:06 AM
odie780's Avatar
odie780
wiring dilema
>on?
Sounds to me you have a short not a grounding problem. Not sure what you are pulling with but if I where to guess you have yellow turn signals. If that is the case your isulator box is bad.
Old Jun 5, 2002 | 03:34 AM
RV ANDY's Avatar
RV ANDY
wiring dilema
SOUNDS LIKE U-HAUL WIRING!
Old Jun 6, 2002 | 06:07 PM
greghoffmann
wiring dilema
Indeed the fuses blowing were due to a loose wire in the plug on the trailer side.
Any thoughts on the flasher deal. They did work for one day as wired now . The problem is when the flashers are on and I step on the brake they stop flashing .
Old Jun 7, 2002 | 12:35 PM
HotWhlz85's Avatar
HotWhlz85
wiring dilema
When you say flashers do you mean emergency flashers or turn signals? My emergency flashers stop flashing when I have my foot on the brake on my 85 F150 regardless of whether I am towing or not.
Ron
Old Jun 7, 2002 | 06:29 PM
greghoffmann
wiring dilema
Yes I do mean the emergency flashers. Are they supposed stop blinking when the brake is on. It does this with and without the trailer
Old Jun 7, 2002 | 06:45 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
wiring dilema
Greg, I think it's because there is only one bulb with two filaments to perform three tasks. The brakes and flashers are shareing the same filament.
Old Jun 7, 2002 | 07:11 PM
HotWhlz85's Avatar
HotWhlz85
wiring dilema
Greg, I don't know how many year models did this (I think the later year models keep on flashing). But stepping on the brakes stops my emergency flashers from blinking on my 85. Does it on my 85 Corvette and 82 280Z too. I can't give you the techical reason why but horsepuller's explanation makes sense. What model truck do you have?
Old Jun 8, 2002 | 06:06 AM
greghoffmann
wiring dilema
My truck is a 1971 F-350 one ton dump . If this is how they are supposed to work then life is good and one less hassle to deal with. Thanks guys.
Old Jun 11, 2002 | 10:39 AM
jim henderson's Avatar
jim henderson
wiring dilema
Old Jun 17, 2002 | 07:07 PM
dpattonfl's Avatar
dpattonfl
wiring dilema
A kind of related topic.
On a 1969 F-100 I had once, when the emergency flashers and a turn signal were both on, holding the brake on would supply power to the radio. I saw it on one other 69 Ford truck also.
