Radiator Back Pressure
Old Mar 25, 2009 | 06:49 PM
Bluecrew250's Avatar
Bluecrew250
Question Radiator Back Pressure
What causes back pressure on a 94 7.3 F-250 turbo I just put a new radiator in because it was about to blow the neck off The first thing I thought of was the thermastat not opening all the way My uncle said it was a head gasket HELP!!!!!!!!!!
Old Mar 25, 2009 | 08:00 PM
starmilt's Avatar
starmilt
Both can cause it. Is the water circulating.
Old Mar 25, 2009 | 08:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Bluecrew250,
Welcome to FTE and the IDI diesel forum.
Head gasket or possibly the valley pan gasket are the cheap possibilities.
Cavitation, cracked block and cracked head are the not so cheap possibilities.
Are you loosing coolant?
How much boost are you running?
Do you use SCA's in the coolant?
How many miles on the engine?
How much pressure and how fast is it building?
Old Mar 25, 2009 | 09:30 PM
Bluecrew250
Dave Yes I've had to add coolant, im not sure how much boost just bought the truck in August but I think it is the stock setting what ever that is Is there any way to find out?I don't run any SCA's in the coolant Theres 127k on the engine Im not sure how to answer you last question I'll give it a shot I but the radiator in an filled it Drove it about 10-12 miles shut it of an raised the hood an there was water around the neck My guess was it came back up throw the over flow an just setteled there when it cooled off I check it an had to add about a quart of water
starmilt yes
abe
Nov 12, 2013 01:56 PM
Myfreeford
Sep 18, 2012 02:25 PM
cowboy117
Apr 22, 2011 03:07 PM
dyoungen
Aug 16, 2009 09:33 AM
flanker
13
Apr 14, 2004 02:34 PM
