adrenaline installed! and the rest of the story
Chris, SOTP feeling with Bill"s tunes is awsome. the truck is very smooth and just pulls and pulls. with Jody's tunes it always felt kinda like a 2 stroke bike. By that I mean pipey, you had to hit the power band and then it pulled. that feeling is all gone. now it just goes.
More info in my truck clean fuel filter, 60-65 psi at WOT, Tymar filter with Big Boost AFE, 5 in exhaust DFA CCK fuel mods
Hey Barney,
That sounds awesome! Glad we could make you smile. Bill definitely wants to get a second look at the high hp program. The biggest reason the pressure is dropping is because of the pulse width; he definitely needs to readdress that (that came directly from Bill -- I don't pretend to know what I'm talking about -- now, you wanna talk F-150s? I am SO there. )
Bob mentioned you'd be swinging down this direction in a few weeks. If for some reason your plans change, no worries! Bill (and maybe the boys and I!) will be going out to Washington in July for Dynomite's Grand Opening of their new shop and Dyno Day. He will be arriving a few days early so that he can live tune some customers' trucks (this ISN'T part of Dynomite's weekend -- it's a PHP thing).
Pocket, the system seems tight. 10-11% duty cycle at idle. The way it was explained to me was you can only keep a stock injector open for so long. If the injector is commanded open any longer it just becomes a big oil leak as the plunger is already down and has no more fuel to push. the higher HP tunes have the larger PW. as soon as Fuel PW goes over 3.5ms it seems to drop pressure. I could have gone with a Pulse, or Stealth or Terminator and it would have give me way more oil than I than I needed. and rightly so, a 2000.00 oil pump should work better than a 500 oil pump. But I also would have never seen the difference in tuning either. I may have a job coming up in Georgia for the next 4-6 months and if thats the case, I'll just have Bill custom tune the truck. I will be leaving Idaho April 1 headed for Colorado Springs and then up tp Rapid City SD so I'll have 12-1300 miles of towing on the set up and I'll be able to post some mileage numbers then.
stock injectors,stock turbo
That's why I figured something was wrong. Bob has been doing a lot of testing with the Adrenaline and AFAIK yours is the first pump to be losing pressure like this. Your numbers at idle may be fine, but I'm just curious if there is something else happening that's causing this issue like a bad injector o-ring or an injector pissing oil out.
As for custom tuning, yes Bill can make adjustments to try and keep ICP higher. Still it doesn't address what's really happening, and is potentially only a bandaid fix if there is in fact something else wrong.
This is the first time I have ever heard that somebody elses chip works better that a DP.
..... Bill, Tony, Jody, David, and others have done quite a bit with their tuning. Every customer has their own preferences, and sometimes they like the tuning styles that a different person puts into the programs. That's why I did live tuning on my truck. I liked Jody's standard tunes, but they didn't quite match up to the way I really wanted my truck to drive. He made a lot of changes to my programs and they vary quite a bit from the original tunes. I think being a tuner is one of the hardest jobs to have in the PSD world, because so many customers have such different trucks and different driving styles. It's impossible to find a "one shoe fits all" tune.
Cookie, stock injectors. Chris, stock pump numbers averaged 100 psi lower with the DP tunes. Thats why I was convinced I had a weak pump. now I'm not so sure. I'm all ears as to where the rest of my pressure is going. as a side note. no chip at all gave me these numbers Fuel PW 3.2 IPR duty cycle 35% 2750 psi
Barney
Barney
I know, I know. As long as I don't get laid of on Friday I'll definitely have it done Saturday. Actually, I'll do it Saturday even if I do get laid off. It's paid for.
I do have a question.....Where in the system is the pop off valve? The IPR regulates the pressure, up to 4000 psi where the book says there is a mechanical pop off valve there to protect the injectors. Is the pop off valve part of the pump, or is it built into the front cover, or the engine, or what? I keep re-reading Barney's post and I just keep thinking something is bleeding off way too much pressure.
What if a poppet in an injector was stuck open and the HPO was pumping straight through? Could that do it? A buzz test would find that right?
okay okay, I' ve been busy beating my head against a 6.0. so i missed all this. I agree with Pete and Curtis, tuners all have their styles. And I'm Not Throwing Rocks at Anybody! I believe the pump will put out 4000 PSI and i think if you've got jody's tunes and like them, thats great. What I believe I'm fighting is the fact that my truck is an F550 and nobody and I mean nobody has my computer code in their data base. I've fought this battle before. Ford factory settings limit my HPOP to 2750 period. F250 or 350 are different. If you drive a "little" truck you should have no issues at all. The Adrenaline will put out what ever your demand is if your computer will let it.
Curtis the injector buzz test comes up fine and cylinder contribution comes up very good.
Corey, thanks for the offer. but I'm pretty sure I'll be in the Atlanta area so we should be able to touch base there. Tell Bill THANK YOU for the prompt service.
Barney
Barney
#28
#30
