Sponsored by: Real Truck
97 f250
Old Mar 24, 2009 | 07:56 PM
aquaman05's Avatar
aquaman05
97 f250
i have a 97 f250 2 wheel drive 460 7.5 motor. I was changing the plugs,wires,fuel filter. I kinda thought i might change the o2 as well but im not sure where this is.
Can someone help me out here.
thanks
Old Mar 24, 2009 | 08:36 PM
Gofigurethis_01's Avatar
Gofigurethis_01
On the exhaust pipe by the starter, I think?
Old Mar 26, 2009 | 05:22 PM
aquaman05's Avatar
aquaman05
does this mean i have to take the exhaust pipe apart to change this ?
Old Mar 26, 2009 | 06:49 PM
enduro4231's Avatar
enduro4231
No, the O2 sensor can usually be removed using an adjustable or open-end wrench of the correct size, but some PB Blaster may be necessary. Not sure about your truck, but some vehicles have an upstream and a downstream O2 sensor. That is, one before and one after the cat.
In either case, just unplug, unscrew, and screw the new one in place with a little anti seize on the threads, then plug back in and you are good to go.
Bigal700
May 9, 2014 11:49 AM
skidrow01
Modular V8 (4.6L, 5.4L)
Feb 29, 2008 04:14 PM
Motley Crew
Sep 9, 2007 10:52 PM
jermdawg
1997 - 2003 F150
May 11, 2006 09:22 PM
