p0603 - internal control modual
Old Mar 24, 2009 | 06:22 PM
rideracelivemx7's Avatar
rideracelivemx7
engine code, what do you guys think? has odd idle at astart up for 5 seconds and its inconsistent
Old Mar 24, 2009 | 07:28 PM
Cuda_jim's Avatar
Cuda_jim
Keep Alive Memory KAM, It means that yo have disconnected the batteries. No big deal.
Most diesels run a little rough when first fired up or in the colder temps.
Old Mar 24, 2009 | 08:09 PM
rideracelivemx7
but mines every single time i start up no matter if its hot or cold and its getting annoying, another code was EOT sensor, doesnt this affect the glowplug cycle?
Old Mar 25, 2009 | 05:32 AM
Cuda_jim's Avatar
Cuda_jim
It would have been better if you mentioned all the codes or symptoms in the first place.
The EOT is your starting issue and...Yes, it controls the amount of time the the GP's are ON. But more importantly....It also controls the the timing and amount of fuel required for starting no matter if it's hot or cold. If the EOT is shot the PCM thinks the engine oil temp is -29ºF every time you start the engine.
Old Mar 25, 2009 | 08:47 AM
rideracelivemx7
well that would make sense, yeah sorry about that, is it a quick sensor fix or is it much nore than that? becuase if bits expensive im bribnging it back to the dealer and they will pay for it
Old Mar 25, 2009 | 08:52 AM
rideracelivemx7
i appologize for that, but yeah that would make sense, how much is the fix? is it a sensor i can jet to ford and grab or is it expensive? becuase if thats the case im breinging it back to ther dealer and they will fix it for me
Old Mar 25, 2009 | 12:43 PM
Cuda_jim's Avatar
Cuda_jim
Not sure how much for the sensor. Here's some part numbers
Oil Temp Sensor (EOT) , Engine
* International) 1814320C1 (engine serial # 375548 and below)
* (International) 1824451C1 (engine serial # 375549 and up)
Oil Temp Sensor (EOT) Connector, Engine
* (International) 2501106C1 (dealer must get these in 10 packs. May or may not order if you only want one...)
* (Ford) E1AZ-12A648-A (not available?)
("http://www.terminalsupplyco.com/default.asp") FPT-91-6995
Here's the Factory repair procedures:
File Type: pdf
File Type: pdf
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
