Wheel bearings 2002 Explorer
Old Mar 24, 2009 | 06:09 PM
Lightningfastmatt's Avatar
Lightningfastmatt
I was wondering if anyone has any tricks to removing and changing out the rear wheel bearings on a 2002 Explorer. It is a 4x4 and I am going to tear into it tonight. Thanks
Old Mar 25, 2009 | 06:29 AM
Ultramagdan's Avatar
Ultramagdan
Welcome to the site!
I moved your question to the proper forum.
Old Mar 28, 2009 | 09:09 AM
steve(ill)'s Avatar
steve(ill)
if you have an independant rear suspension, the rear bearing is a sealed unit with the 5 bolt hub. the bearing pressed into a spindle assembly. You take the entire bracket off and go to a 12-20 ton press to disassemble. you must push the parts to gether in the right order to reassemble. dont load the outer race by pushing on the inner race to assemble. its ben 2-3 years since i did this, but remember part of the story. ther is a writeup on this page somewhere.
woodmansnj
Jul 26, 2011 01:47 PM
mdharnois
Feb 2, 2010 06:29 PM
bradcdavis00
Jan 18, 2010 10:34 PM
don96exp
Mar 21, 2006 07:50 PM
bauerexpy4x4
Dec 23, 2005 03:40 PM
