oil fill
Old Mar 24, 2009 | 01:33 PM
Miguy's Avatar
Miguy
oil fill
what would happen if 16 qts of oil were put into the 6.0, i think that happened on my truck on its last oil change, some tell me don't worry about it, its a ford, others say the engine is junk now.
Old Mar 24, 2009 | 01:47 PM
Kep4's Avatar
Kep4
Jäger
Check the oil level on the dipstick and report back with your finding. Please be specific regarding the oil level. Is it within the cross hatch marks? Above or below and by how much exactly?
Someone stating your engine is now junk is being quite dramatic.
Old Mar 24, 2009 | 02:24 PM
Miguy's Avatar
Miguy
its a bubble type dipstick and the level is above the bubble ill attempt to take a pic of it to show better,
i have a pic in my profile hope that will do
Old Mar 24, 2009 | 05:12 PM
juneau76's Avatar
juneau76
Pics from his album:
I can't see the bubbles very clearly.
Old Mar 24, 2009 | 06:53 PM
6litrefan's Avatar
6litrefan
If i am seeing right looks like to me that you have oil all the way past the plastic (guage) area on the tip of dipstick....meaning as you stated that it was way overfilled....how much have you run the truck with this amount of oil???
Old Mar 24, 2009 | 07:00 PM
toolman05kr's Avatar
toolman05kr
Drain a little out, adjust the level to the middle of the bubble and you should be OK.
Old Mar 24, 2009 | 07:20 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Hope you have a Fumoto Valve installed on your oil pan.
Old Mar 24, 2009 | 09:05 PM
toolman05kr
If not, wear an old shirt.
Old Mar 25, 2009 | 03:01 AM
Miguy's Avatar
Miguy
yeah im doing that thanks. but over filling the oil would or could possibly blow seals in the engine right or could worst damage be done
Old Mar 25, 2009 | 06:49 AM
bismic's Avatar
bismic
The first thing you would notice (according to Ford TSB's) would be rough running. As I understand the explanations, the oil (when overfull) will aerate and this interfere's with the actuation of the injectors.
Your truck holds apprx. 18 quarts, so adding 16 at an oil change is apprx. 5 - 10% over (depending on whether you are a "14 quart refill person" or "15"). I can't see how this little extra amount would affect the pump performance curve to develop the extra pressure to affect seals. In addition, I have read the manuals (PC/ED, WSM), and watched 5 6.0L Forums for a number of years and never seen any warning of blowing seals from a slight overfill. IMO - drain the extra oil and you should be just fine.
