Performax HPOP Gauge Install...
Old Mar 24, 2009 | 10:05 PM
CSIPSD's Avatar
CSIPSD
Originally Posted by MiamiPSD
What does the hpop gauge do? What type of reading and where does it mount to on the engine?
High Pressure Oil (HPO) is what pushes the plunger in your injectors, pushing the fuel out. Pressures run from 600-700 at idle to 3000-4000 at WOT. A High Pressure Oil Pump gauge reads what kind of pressure your pump is putting out. If you have a program that is asking for too much HPO, performance will suffer, or if your pump is weak, peformance will suffer...
Here is just a quick video I took a while ago, its of my Scan gauge with both Duty Cycle, and HPO pressures.
Duty Cycle is how hard the pump is working... Anything more then 40-45% is too hard... I need a new pump.
YouTube - 54% duty cycle
Old Mar 24, 2009 | 10:11 PM
guitarpicr's Avatar
guitarpicr
Looking good Clay -What are the 2 black vent looking things on the bottom of the dash? Probably a dumb ?
Old Mar 24, 2009 | 10:15 PM
CSIPSD's Avatar
CSIPSD
Looks like a set up for switchs... two banks of 3...
Old Mar 24, 2009 | 10:54 PM
bdrummonds's Avatar
bdrummonds
and on a side note Isspro makes it super easy to install the HPO guage in the Performax line. The engine connection is literally a pigtail that is plugged into the ICP sensor, and run to the Performax ECM.
Looks great Clay.
Old Mar 24, 2009 | 11:22 PM
superduty4x4's Avatar
superduty4x4
Clay- HABU my friend (hook a brother up). Considering switching from Isspro EV's to Performax...
Old Mar 24, 2009 | 11:47 PM
MiamiPSD's Avatar
MiamiPSD
CSIPSD,Thanks for the detailed explanation.............might look into getting one.
Old Mar 25, 2009 | 05:33 AM
MiamiPSD's Avatar
MiamiPSD
Could you see over the 4000 max on the gauge with dual hpop's or the new pumps from Bob at Dieselsite?
Old Mar 25, 2009 | 06:26 PM
Bigfwt04's Avatar
Bigfwt04
I think it might go over that with the Adrenaline. I am hoping to order one sooner than later so maybe I will be able to tell you
Old Mar 25, 2009 | 07:03 PM
CSIPSD's Avatar
CSIPSD
Realistically no, 3800psi will start to cause the poppets to float. I can not see any reason to go over that pressure.
Those are a nice looking little pump.
Old Mar 25, 2009 | 07:09 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Got your CPS in today so I will get it out first thing tomorrow Joe. Hopefully that is all it is....
Old Mar 25, 2009 | 07:50 PM
CSIPSD's Avatar
CSIPSD
LOL... I sure hope so. I grow tired of working on the GBB (Great Big Bitch...LOL)
Old Mar 25, 2009 | 07:51 PM
superduty4x4
Got another?
Old Mar 25, 2009 | 07:57 PM
  #28
Riffraff Diesel
PREMIUM SPONSOR
Originally Posted by superduty4x4
Got another?
Yeah, yours and the other should be in tomorrow. Joe actually got one from another members allocation. Don't worry, I wouldn't pass you up
Old Mar 25, 2009 | 11:12 PM
  #29
superduty4x4
Sweet! I'll feel a lot better having another blackie as a backup.
Old Mar 25, 2009 | 11:24 PM
  #30
TNT in Round Rock's Avatar
TNT in Round Rock
I'll add another thumbs up to the Performax line .. I have 11 of them installed and they are a BREEZE to do once you have the main control unit set and wired ..
