Running Lean? Smoking?
Old Mar 24, 2009 | 11:02 AM
Dean88's Avatar
Dean88
Well, the ol girl has been acting wierd the past couple days, she seems to be low on power and smokes real good even warmed up once wound up past 2.5K. She's always smoked a little, but she is def killing all the mosiqituoes in the county now.
What could this be a sign of?
Old Mar 24, 2009 | 11:20 AM
jmmartin's Avatar
jmmartin
possibly air intrusion? mine is doing the same, but i know my return cap on #8 is leaking
Old Mar 24, 2009 | 12:16 PM
starmilt's Avatar
starmilt
This is probably mute and dumb but what is your air and fuel filter like.
Old Mar 24, 2009 | 02:30 PM
LCAM-01XA's Avatar
LCAM-01XA
air intrusion at the return lines makes no difference on how the engine is running once tis running, as the pump moves more fuel than the engine ever needs so the excess fuel pushes any air back to the tank, and at the engine you get a fuel leak instead of an air intrusion. Air intrusion in the return lines affects startup, as it very efficiently prevents it.
Air intrusion before the lift pump tho, that's an evil thing - how's your fuel line under the engine? But yah, check the filters first...
Old Mar 24, 2009 | 06:02 PM
jmmartin's Avatar
jmmartin
what ticks me off is i just put new filters on about 500 miles ago... its been doing it for about a week for me
Old Mar 24, 2009 | 06:03 PM
starmilt's Avatar
starmilt
Might have gotten some bad fuel.
Old Mar 24, 2009 | 10:58 PM
jmmartin's Avatar
jmmartin
i hope that is all it is, but i use only one station to fuel, and it does enough business to get 1 - 2 fuel dumps a day, i figured with that much business it would be a good fuel source.
Old Mar 24, 2009 | 11:52 PM
Dean88's Avatar
Dean88
Fuel Filter is only a few thousand miles old, but it may be fuel line before the IP, I'll give a better look tomorrow.
I don't think its my fuel because I only buy from one station.
Old Mar 25, 2009 | 02:36 AM
KJLYPW's Avatar
KJLYPW
So how old are the injectors- worn out will not pop on/off right, drip fuel and smoke all the time!?
Old Mar 25, 2009 | 09:37 AM
Dean88's Avatar
Dean88
They are still the orginals, so I know they have over 250K miles on them, not really sure how many more tho, cuz the truck hasn't had a speedo in years.
I knew they are getting old, but they went from just a little smoke when she's cold to turning into a smoke machine in one day.
Old Mar 25, 2009 | 02:18 PM
bad12jr's Avatar
bad12jr
Change the injectors and probably the IP to. Mine was doing the same after new injectors. The pump was giving up.
BigJohn61
Nov 17, 2016 03:17 PM
T-wood
16
Feb 5, 2014 11:28 PM
eddiedebb
Oct 9, 2013 10:03 AM
mmenzies
Nov 15, 2012 05:56 PM
thesargent44
20
Aug 5, 2006 10:28 AM
