Testing the trailer plug
Old Mar 29, 2009 | 02:09 PM
rbaker6336's Avatar
rbaker6336
Originally Posted by tnardo
i'm having issues also....what prong is for the trailer brakes, i dont have the cover.....
and i have a tekonsha envoy brake controller it was in there when i bought it, it looks like they used the factory harness, when it works, i can only use it manually, do you think they did something wrong or is the factory harness not setup for "automatic braking"
How to Wire your Car or Truck for Trailer Lights
Old Mar 29, 2009 | 02:16 PM
guitarpicr's Avatar
guitarpicr
That's a great link there Ray.
Old Mar 30, 2009 | 08:55 AM
flyguy99pwrstrk's Avatar
flyguy99pwrstrk
Tnardo. IF you can only use the brake controller manually than I would check the red wire that comes off of the controller and goes to the brake switch just above the brake pedal. stick a test light on the red wire behind the brake controller and push in the brakes on the truck. IF you don't get anything on your test light there is a connection problem. If your using the factory harness that can be a pain to trace down. If your test light does light up then its more than likely the brake controller itself.
Off the brake controller the wires are as followed for anyone that doesn't know. White=ground, Black=12V power, Red=Stoplight, Blue=output to trailer brakes.
Generally if your having problems with your brake controllers the most common problems are Bad fuse or circuit breaker under the hood. Circuit breakers are generally installed when the vehicle does not have the factory trailer wiring. Just because it has a hitch on it doesn't mean it came with the factory trailer package a common mistake with people.
If your truck has the factory harness it is very seldom it is a wire under the dash more so on the connections coming out of the brake controller to the factory harness.
Another place to check is inside the plug on the truck. Water can get in and corrode the wires. Bad connections can do wonderful things when your trying to tow a trailer.
Also on my 99 I know I had a problem where the main harness comes to the back of the truck. My trailer plug wires go up and plug into the main harness. My trailer brake wire was rotted out inside the plug so i had to by pass the little factory plug run a new wire to the trailer plug
Hope this helps guys
And if your having problems with messing around with test lights find your self a little tester like this. or stop by a local RV shop they should have a tester like this or something similar
[IMG]<a href="http://s125.photobucket.com/albums/p61/flyguy92325/?action=view&current=IMG_0504.jpg" target="_blank"><img src="http://i125.photobucket.com/albums/p61/flyguy92325/IMG_0504.jpg" border="0" alt="Photobucket"></a>[/IMG]
Old Mar 30, 2009 | 12:06 PM
jt371's Avatar
jt371
______
One of the service trucks at work had the wire corrode right inside the factory connector on the back of the trailer plug. Was able to take it apart and reuse the old pin on the wire after I cut and restripped it.
Old Mar 31, 2009 | 07:38 AM
89BlackBeauty's Avatar
89BlackBeauty
Make sure you are getting a good ground when you test. I had a bad wire in mine that I kept chasing. Also, make sure the terminals are clean. I didn't see above if you where getting the trailer lights to work as well. Most of the time the brake controler has to "see" that it is hooked up to work, and I think that the ground connection is how it sees that. If your trailer hookup does not include a ground, then it will ground through the ball. If the ball is rusty or has a fair amount of grease on it it may take some driving to make the connection.
Old Apr 2, 2009 | 12:03 PM
preppypyro's Avatar
preppypyro
Just to update, Ive been away for a week or so, and havent played around with it anymore. I tried the brakes of another trailer and the brakes worked, but I just couldnt get the test light to go on when I was testing. i will try it again, and this time I will hook up the trailer just like i was going to tow it. Last time i didnt, but it still should have worked! Will keep everyone in here updated and thanks to everyone so far for the useful help, and tips and whatnot.
Old Apr 2, 2009 | 01:25 PM
89BlackBeauty
If you have two people, you should try to use a multi-meter instead of a test light. I believe the center terminal is ground, and the 2 o'clock terminal is brake. That way you can insure you have good ground, and if you are getting voltage when the brakes are stepped on.
Old Apr 2, 2009 | 01:46 PM
rbaker6336's Avatar
rbaker6336
the ground is at 5 oclock and brakes are at 7 oclock the center is aux
F350Man79
Mar 21, 2016 08:03 PM
silentrunning
Feb 24, 2012 06:20 AM
dangerranger10
1983 - 2012 Ranger & B-Series
Jul 3, 2010 07:19 PM
drewk4
Jan 31, 2010 01:04 PM
FordTrucksKickGM
All Things Towing
Jan 9, 2008 03:25 PM
