Sponsored by: Real Truck
auto hubs
Old Mar 24, 2009 | 07:03 AM
deezel's Avatar
deezel
auto hubs
front auto locking hubs don't seem to be unlocking on 2002 f350.jacked up and spun wheel and axle shaft moves with it.also have small vibration.thanks for any replies in advance.
Old Mar 24, 2009 | 09:33 AM
aldridgec's Avatar
aldridgec
Prob need new hub lock on that side, or both sides. But you have to make sure the vacuum signal is working. There are lots of threads on how to service and check the hubs so do a quick search!
Old Mar 25, 2009 | 12:33 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I think it might be the needle bearing that's inside the wheel bearing where the axle stub rides (inner spindle bearing).
Remove the locking hub (remove the snap ring and the hub should pull out - might need a rubber mallet to beat it around a little bit). Then spin the wheel and see if the axle still rotates.
