Sponsored by: Real Truck
2007 f250 towing problem
Old Apr 13, 2009 | 12:07 AM
  #31
btm991's Avatar
btm991
thanks im going to tell them to try it
Old Apr 13, 2009 | 11:55 PM
  #32
btm991's Avatar
btm991
just thinking a little bit, but could putting 35in tires on make this happen.
Old Apr 14, 2009 | 05:52 AM
  #33
Erik727's Avatar
Erik727
Just had same problem with my 04 250 6.0. Wouldn't pull my 11,000 lb toyhauler worth a crap. First time they found a split cac duct,,,second trip to ford ,they changed IPR sensor and connector and the ICP sensor,,,tows awesome now
Old Apr 14, 2009 | 06:34 PM
  #34
btm991's Avatar
btm991
just got the call from ford and they said it was the ficm
Old Apr 18, 2009 | 02:05 AM
  #35
btm991's Avatar
btm991
not only was it the ficm, they also put in a whole new turbo. and it was all under warranty!!!!
Old Apr 18, 2009 | 12:21 PM
  #36
bunklash's Avatar
bunklash
Yeah for happy endings!
Old Apr 18, 2009 | 06:09 PM
  #37
LiftedBlackHD's Avatar
LiftedBlackHD
This is why the 6.0 has a bad reputation. You've got people with NO CLUE of how to properly maintain or care for a high dollar, quirky diesel engine running it into the ground then complaining about it. 65K miles and 2 fuel filter changes...WOW!
Old Apr 18, 2009 | 07:49 PM
  #38
Greg B's Avatar
Greg B
The 6.0L has a bad reputation because it earned it. I did all of the maintenance on my 05as scheduled and it still was a nightmare from hell. Bone stock, HPOP, EGR cooler, EGR valve cleaning every 15k miles, and head gaskets problems at under 50K miles. It probably had an injector or 2 going bad as well. And the dealer hosed up the fuel mileage with a non-requested reflash and would not make the effort to get the FICM reprogrammed to restore the fuel economy. I have to put most of the blame on Navistar and Ford for even building this engine the way they did. Had they done the things necessary to build this engine to last and perform instead of cutting corners it would have turned out much better for everyone. Probably the ones who were shafted the worst were the employees at the Indianapolis Navistar engine plant that are losing their jobs as a result of Ford and Navistar divorcing ugly and the residents of Indy who will lose more tax base in the end when Navistar levels the plant to avoid paying property taxes on it.
Old Apr 18, 2009 | 08:18 PM
  #39
bunklash's Avatar
bunklash
LiftedBlackHD said, "You've got people with NO CLUE of how to properly maintain or care for a high dollar, quirky diesel engine running it into the ground then complaining about it".
Just wondering where that came from? It may be something I don't understand, but what does the FICM and turbo have to do with fuel filters?
Old Apr 18, 2009 | 10:02 PM
  #40
Greg B's Avatar
Greg B
Fuel filters and FICM and turbo may not be related. I changed my fuel filters every 15-16000 miles and never saw a bit of contaminate in the fuel. If all the fuel used was of a good quality it's possible that doubling the interval on fuel filter changes may not kill the engine. I wouldn't want to try it, but I do know some who have. If the PCM was ever reflashed the FICM could have been messed up. It's possible for the FICM to mess up on its own. Turbo issues are known to exist on 6.0L. Vanes do stick. As long as there was a happy ending all is well. I would even buy another 6.0 if it was cheap enough and the mileage was right. But I would really prefer a 7.3L. More reliable and less expensive to maintain. But that Torque-Shift tranny sure was nice, though.
Old Apr 18, 2009 | 11:16 PM
  #41
btm991's Avatar
btm991
we actually have had more than 2 filter changes because my dad who gave me the truck just kept bringing it it to get serviced every 20,000 miles.
Old Apr 18, 2009 | 11:17 PM
  #42
btm991's Avatar
btm991
does anyone know if a turbo back exhaust would void the warranty
Old Apr 19, 2009 | 10:31 AM
  #43
CampSpringsJohn's Avatar
CampSpringsJohn
A turbo back shouldn't void any warranty. The vanes on the turbo are prone to sticking, so that's why it's a good idea to get the truck out and drive it like you stole it on occasion. Keeps everything moving free.
Old Apr 19, 2009 | 10:56 AM
  #44
Greg B's Avatar
Greg B
4" turbo back exhaust should not void the warranty. It is up to the dealer if warranty gets voided, though. 4" turbo back exhaust won't help fuel economy, but it will lower exhaust gas temp a couple of hundred degrees, which is a good thing. The best thing a person with a 6.0L can do is drive them regularly on longer trips of 50 miles or more, don't idle them excessively, and change oil and filters religiously on schedule. These engines are notorious for shearing oil fairly quickly. That's probably because of the EGR system that's used. If you do run a programmer, use a tuning level that keeps cylinder pressure in tolerance. Don't get extremely aggressive on tunes or you are asking for head gaket problems.
hotpep1
2004 - 2008 F150
Apr 3, 2014 09:41 PM
hotpep1
2004 - 2008 F150
Apr 2, 2014 11:43 AM
sportsmom3444
2004 - 2008 F150
Apr 22, 2013 10:04 PM
Packrat Super duty
Oct 17, 2007 12:29 PM
