More injector info .........
Old 04-03-2009, 08:37 PM
brickie's Avatar
brickie
brickie is offline
I'de say this is stickey!
Old 04-13-2009, 11:31 PM
bismic's Avatar
bismic
bismic is online now
Received 2,522 Likes on 1,754 Posts
Here are a couple more good injector links:
Thanks to 04F-250mark
YouTube - Common Rail Injector
Already in the Tech Folder - from Matt (Spartan)
https://www.ford-trucks.com/forums/5...ml#post4355612
Already in the Tech Folder - FICM Guide
http://www.grufmanbil.se/mektips/6.0...tech_guide.pdf
Old 04-14-2009, 05:57 AM
dfooch's Avatar
dfooch
dfooch is offline
Excellent post Mark...very informative.
Old 04-14-2009, 12:43 PM
msgtg's Avatar
msgtg
msgtg is offline
Mark, you need to make the August trip to Carlise for the All Truck Nationals! I too am having to wait before I can rep you again...but you really deserve it Pal!
C'mon up to Carlisle and we'll take good care of you!
Joe
Old 04-14-2009, 12:56 PM
bismic's Avatar
bismic
Joe
I would love to Joe! It actually might work. My son just accepted a job in Nashville, so a trip to see him would put me pretty close (compared to South TX). Thanks for the kind words. I have spent a lot of "quality" time w/ my 6.0 machine - I enjoy sharing. Save the rep points for later (I am trying to catch up w/ you!)
Old 04-14-2009, 02:44 PM
msgtg's Avatar
msgtg
msgtg is offline
C'mon Pal...Your first (they're likda like Lay's Potato Chips...betcha can't have just one)cold frosty is on me!
Last year we talked about trying to set up a couple of simple tech sessions for the guys who show up. You'd be a natural!
Hope to see you in August!
Joe
Old 04-16-2009, 10:48 AM
bismic's Avatar
bismic
A few more links for reference:
http://turbodieselforums.com/downloa...20Injector.pdf
<TABLE style="WIDTH: 582pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=776 border=0 x:str><COLGROUP><COL style="WIDTH: 582pt; mso-width-source: userset; mso-width-alt: 28379" width=776><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 582pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=776 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 582pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=776 height=17>http://turbodieselforums.com/diesel_6.pdf</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 582pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=776 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 582pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=776 height=17>Compression Bubble Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 582pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=776 height=17>http://www.forddoctorsdts.com/articles/article-08-03.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 582pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=776 height=17>The old Balloon test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 582pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=776 height=17>http://www.forddoctorsdts.com/articles/article-05-03.php</TD></TR></TBODY></TABLE>
Balloon test explained on the video link below (about the 4 minute mark).
mms://multimedia.ford.com/seopts/Tech6_250k.wmv
(enter the link above in your browser)
Old 04-19-2009, 12:28 PM
brickie's Avatar
brickie
brickie is offline
I found this today,figured it is a good addition to this thread. It shows all the bits of a dismantled injector,wear patterns and more. 6.0L injectors
Old 04-27-2009, 06:25 PM
krommag's Avatar
krommag
krommag is offline
spread sheets
Hey, can you resend the spread sheets ,, can you send them again to fred.bankroll at gmail.com or krommag at yahoo.com,, or nichols123 at clearwire.net
thanks
Old 04-27-2009, 07:08 PM
krommag's Avatar
krommag
krommag is offline
spread sheets
Thanks for sending them I put them on my computer, just finish with them, it will be a BIG help for me to understand the engine and my truck, thanks again for your help
fred
Old 04-27-2009, 07:16 PM
bismic's Avatar
bismic
Glad to do it. Get to know the Excel search feature and you can find something on just about every part of your truck.
Old 04-29-2009, 04:00 PM
bismic's Avatar
bismic
Here is a good article on the 6.0L - Part 6 includes info on injectors:
TheDieselStop.Com - www.thedieselstop.com
  #28
Old 08-19-2009, 03:31 AM
bismic's Avatar
bismic
One easy check for injector problems:
Pull the fuse cover under steering wheel with a flat blade screw driver turn the screws 1/4 of a turn. Pull fuses 20 FICM, 40 Fuel pump, and 103 PCM. You might need a fuse puller or needle nose pliers. Be sure there is fuel above the standpipe. If you want pull fuse 40 last and use the fuel pump momentarily to fill the fuel filter housing. Then have someone crank while you watch for bubbles. Do not crank on it for more than 10 seconds max. This is the easiest way to determine mechanical condition of injectors. What happens is combustion gas will come through the pintle seat and into the fuel gallery in the head and up into the filter.
https://www.ford-trucks.com/forums/8...in-a-6-0l.html
  #29
Old 09-07-2009, 04:56 AM
collinsone's Avatar
collinsone
collinsone is offline
i have 03 w/ 6.0 i have fuel coming out drivers side frnt header starts up fine smoked black grey but lots of diesel coming out exst port help any ideas
  #30
Old 09-07-2009, 07:24 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
So......you removed the drivers exhaust manifold and you have lots of diesel coming out the exhaust port? I think that's what you're saying? You have a failed or improperly installed injector o-ring, cracked injector cup, or cracked head.
Quick Reply: More injector info .........
