Front Brake Pulling
Old Mar 23, 2009 | 08:59 AM
Stroked99's Avatar
Stroked99
Front Brake Pulling
Okay, took my truck in to get the enligment done because the truck was pulling to the right. Get back in the truck it still is pulling to the right. When I step on the the brake it pulls to the right. Now before this, I have replaced the pads, the rotor and the bracket that allows the calpier to "float" and even the "floating" bolts that the braket attaches to. I also have replaced hub too! I have noticed that there is more brake dust on the passenger side rim compared to the driver side. Now I am aware of a little more wear due to the crowns on the road and so forth, but any thoughts on why the brake would be "dragging" again? I am planning on tearing it down this weekend. I the only thought I am leaning towards is the caliper's pistons not retracking when released. Anybody run into this problem? Oh, my truck has 165K on it.....
Old Mar 23, 2009 | 09:03 AM
Ponyboychris's Avatar
Ponyboychris
The pistons could be hanging up on you or a more common problem is the caliper slide pins freezing in their bores and not allowing the caliper to work. I see that you already R&R'ed the slide pins but you may want to give them another look.
03_PSD's Avatar
03_PSD
i bet is your slide pins, maybe you should clean them and grease them up.
Old Mar 23, 2009 | 09:17 AM
Stroked99's Avatar
Stroked99
Greased them really good with a wheel bearing grease. ANy suggestions on what I shold use this time?
Old Mar 23, 2009 | 09:20 AM
03_PSD's Avatar
03_PSD
I used a good synthetic caliper grease.
Old Mar 23, 2009 | 09:24 AM
Ponyboychris
^^^^That's what I used, found a bottle at the local parts store.
Also check to see if the boots got torn or popped loose from the caliper. That would allow gunk to get into the bores. Also, those caliper pins need to slide freely.
Old Mar 23, 2009 | 09:57 AM
Stroked99's Avatar
Stroked99
I will take a look at them. Will have to pay a visit to the local parts store to look for the grease. WIll let you know how I make out.
dynamic
Jul 9, 2012 10:25 AM
cv18sro
Escape & Escape Hybrid
Dec 3, 2009 10:43 PM
RTM
Mar 5, 2009 04:07 PM
1995sho
Dec 7, 2007 10:02 AM
Diesel Dog 250
Jul 19, 2007 09:48 PM
