Sponsored by: Auxito
guage cluster replacement
Old Mar 23, 2009 | 12:55 AM
63F-500's Avatar
63F-500
Does anybody know of a way to bypass the PATS secutity when replacing the cluster without taking to a dealership on a 02 f-150??? I got a used cluster from a wrecker but the truck won't start when the "new" cluster is in it. I know there are legal issues because of the odometer but I am wondering if there is any way I can progam the secutity or whatever has to be done myself??
Old Mar 23, 2009 | 03:07 AM
Bluegrass 7's Avatar
Bluegrass 7
The PCM has a marrige with the PATS system.
The PATS must provide the missing data for the PCM to allow starting.
It is designed this way to be very hard to steal the vehichle by driving it away.
A dealer can program it back. Provide at least 2 original keys so the new code is set in the new keys as well.
Sorry there is no easy way, not meant to be.
Old Mar 23, 2009 | 04:35 PM
thecardoc's Avatar
thecardoc
If the truck from the junk yard had its PCM still intact and has the same options as your truck, swap it and use the keys from the junk truck then the your truck should start .
Old Mar 24, 2009 | 09:38 AM
KingRanchMan02's Avatar
KingRanchMan02
Make that your keys with the ID chips from the junk trucks keys in your keys.
