Rear Femder rust
Old Mar 22, 2009 | 10:31 PM
Welk49's Avatar
Welk49
Rear Femder rust
Well my PS rear fender was starting to rust, so I took the time today to cut all the bad stuff out, and will be putting the new panel in tomorrow. Will get some pics. The biggest problem I have seen so far is dirt and moisture get caught between the inner fender and fender. The inner fender is just about non useable anymore, will have to see if somewhere local has one, if not I have to get one from LMC. Now the outer fender wasn't to bad I caught it early enough, a little metal and body filler it will be ok. Has anyone else fixed theres before?
just noticed I typed rear femder in the title instead of fender
Old Mar 23, 2009 | 05:47 AM
WALJON's Avatar
WALJON
Every truck I have had has rusted in the same spot except this one and that is because of a rust proofing product I use called rust check to combat the rusty,s over the back tire they pull the tail lights out drill two holes and insert a long wand and spray the inner panel between the two skins it has worked for me I have not one speck of rust and still original paint.
good luck on the panel replacement
Walter
Old Mar 23, 2009 | 07:14 AM
Welk49's Avatar
Welk49
yeah once I get this fixed I'm going to look into something like that.
