noisy clutch?
Old Mar 22, 2009 | 01:27 PM
steeldashes's Avatar
steeldashes
noisy clutch?
I have a 94 crew cab dually that I put a banks turbo on ,that I really like, the miles show 155k . I'm getting a growling noise from clutch or trans when taking off and also going down the road , in any gear mostly when a load is on it . It started out just doing it when backing up a slight incline but now does it all the time. The clutch engages smoothly and trans shifts good . Does any one have any ideas? Really enjoy FTE!
Old Mar 22, 2009 | 01:42 PM
starmilt's Avatar
starmilt
4x2 or 4x4 have you checked the oil in tranny transfercase.
Old Mar 22, 2009 | 01:50 PM
steeldashes
4x4 the trans fluid full I see no glitter in the oil and no leaks The 4x4 hi and lo both work normal
Old Mar 22, 2009 | 02:28 PM
Lazy K's Avatar
Lazy K
I assume you do not get the noise with truck stationary and trans. in neutral. I assume you also do not get the noise with all the above but the clutch pedal depressed.
That being the case I would check the drive shaft universal joints and the wheel bearings and the differential fluid.
Old Mar 22, 2009 | 02:35 PM
starmilt's Avatar
starmilt
If you are getting noise in all gears and not stationary I would check the transfercase and rear. Are you getting any vibration.
Old Mar 22, 2009 | 08:48 PM
steeldashes
no vibration and u joints appear ok
Old Mar 22, 2009 | 09:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Crew cab ....two piece rear drive shaft.
Check the carrier bearing.
Old Mar 22, 2009 | 10:58 PM
88f150302's Avatar
88f150302
dose your speedo jump around at all?
Old Mar 23, 2009 | 05:15 PM
steeldashes
carrier bearing appears fine and spedo is smooth and normal
Old Mar 23, 2009 | 05:28 PM
steeldashes
The wife took truck and had local ford mechanic drive it he says it needs the dual mass clutch replaced 1500$ parts alone. I can do this my self , does this sound right ?
Old Mar 23, 2009 | 05:34 PM
starmilt's Avatar
starmilt
Do some shopping the first one I bought right after they appeared was dealer only 1100 bucks. The last one was from amarillo clutch and drive and was 531.00 this has been several years.
Old Mar 23, 2009 | 06:00 PM
EMD_DRIVER's Avatar
EMD_DRIVER
What about doing the "Lucky mod" and just converting it to a SMF (Single Mass Flywheel)? That would be tons cheaper yet!
Old Mar 23, 2009 | 08:19 PM
steeldashes
The mechanic said the single mass has more gear noise, anything to that ? what is the difference?
Old Mar 23, 2009 | 08:26 PM
EMD_DRIVER's Avatar
EMD_DRIVER
The noise is called gear rollover noise. With the SMF, you will get the noise in neutral and at idle. When I installed my 5-speed, I opted for the SMF. I over filled the transmission with a total of two gallons of ATF. There is some noise at idle, but it's really not that bad. With the DMF's being so prone to failure and so expensive, I did not want to take that risk. I can live with a little noise once in a while.
