clutch safety?
Old Mar 22, 2009 | 01:23 PM
octaneforce's Avatar
octaneforce
clutch safety?
on a 1992 f150 is there any type of clutch safety that makes it so you have to push the clutch for it to start? my truck isnt starting and i have to touch the solenoid ends together even though it is a brand new solenoid. i think the clutch safety may be preventing it from starting with the key (if it has a safety).
Old Mar 22, 2009 | 01:27 PM
nat13_3's Avatar
nat13_3
My 1995 does.
Old Mar 22, 2009 | 01:36 PM
1966Tbird's Avatar
1966Tbird
it probably should, why don't you climb under the dash and take a look it would take you less time to do that than it did for me to type this
Old Mar 22, 2009 | 01:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Look above the pedal for a notched white plastic shaft.
There should be a set of contacts in a little 'carriage' attached to that.
In my truck when you depress the clutch pedal the arm pushes against the contact and completes the connection.
You may need to adjust this farther up the shaft or check the assembly for continuity.
At least that's how it is on my '87
Old Mar 22, 2009 | 03:05 PM
octaneforce
yeah i climbed under the dash and didnt see any type of switch at first but i did it again and now i see what your talking about. i disconnected the switch and jumped it, so now i dont have to jump the solenoid anymore. i guess i need a new clutch switch. -thanks
Old Mar 22, 2009 | 03:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Welcome to FTE octaneforce.
Old Mar 22, 2009 | 05:31 PM
octaneforce
thanks! --------------------
brent1204
1983 - 2012 Ranger & B-Series
Feb 24, 2015 10:19 PM
Shayne7.3diesel
Feb 5, 2013 02:34 PM
econolow
Aug 28, 2008 08:26 PM
lrstaz
Oct 17, 2005 02:16 PM
Old Salt
Oct 30, 2003 07:27 PM
