Bronco Towing
please let me know.I am running on Bridestones right now, will post the exact size when I get back in if necessary. (these were similarly sized to the P265/75Rx15)'s that were on there before)
2. Don't plan on setting any land speed records, allow plenty of time.
3. Since its drawing nearer to winter, make sure you got good tread all around, nothing worse than having a blow out with a loaded trailer. (you should all ways have good tires when towing anyway!)
4. I'd hesitate to tow with a "P" rated tire unless it was a Pxxx/xx/rim XL, If ya need some treads, go with a LT tire, you can always air them down later. (if they're just "P" rated, you might be exceeding the load capacity of the tires themselves)
5. A class III drop hitch or heavier would be very benifical, allows you to level the load out, and pulls alot better.
Good Luck!
super
around using rented trucks from Ryder, etc. and a trailer.
Invariably they would give me a box truck for the towing
rather than a pickup. I asked why and they said to tow a car
or truck, using a pickup was "too small." I got a generic impression
that the restriction had to do with safety. You may want
to talk with a local Ryder or U-Haul. You might be able
to get some generic advice for your situation. I've had
enough hairy towing experiences (none with rental trailer
setups) that I would personally hesitate to do what you
are considering, at least without testimonials from someone
I could trust fairly well. If you decide to go for it,
I would recommend always keeping the speed low, say 50
and never over 55. If you are going to do it often, consider
getting a larger, longer truck (f350, f250 crew cab,
box truck, etc.). My towing experience is somewhat limited
and so someone else with a lot of experience might have
a better feel and be able to override some of my concerns
with confidence. Good luck in any case.
