aux power switches?
Old Mar 22, 2009 | 10:16 AM
templar514's Avatar
templar514
aux power switches?
There are four switches next to my integrated trailer brake controller, marked aux1, aux2,etc. What are they for? Anybody know?
Old Mar 22, 2009 | 10:30 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
They're called upfitter switches. If you were to install extra lights or other electrical components they can be wired to these switches, but they are not connected to anything at the factory.
Old Mar 22, 2009 | 10:31 AM
mxer0022's Avatar
mxer0022
or they can be used for your high idle mod!
Old Mar 22, 2009 | 10:32 AM
1bddelx's Avatar
1bddelx
Switch #4 for me. Works great!!!!
Old Mar 22, 2009 | 10:33 AM
rollerstud98's Avatar
rollerstud98
With those you don't have to go and drill holes in the dash to add switches when you add components to the truck, nice feature to have
Old Mar 22, 2009 | 10:38 AM
1bddelx's Avatar
1bddelx
You also have four wires going through the fire wall and they come out on the drivers side up high under the hood. Mine were not connected. I had to connect them to the switches to make the hot under the dash.
Old Mar 22, 2009 | 11:37 AM
kwyjibo's Avatar
kwyjibo
Ya, like the genius who owned my truck before me. Four beautiful factory switches right there and someone decides to drill a hole and install an 89 cent toggle switch.
Old Mar 22, 2009 | 11:45 AM
templar514's Avatar
templar514
Glad i asked, i thought so. Thanks all.
Old Mar 22, 2009 | 02:40 PM
FlyCanadianGuy's Avatar
FlyCanadianGuy
Huh.... where? Are you sure?
Old Mar 22, 2009 | 02:47 PM
SteveBricks
FTE Emeritus
White, Blue, Red and Black. They come through near the brake booster. They don't necessarily have to do with the upfitter switches - just there to keep you from having to put a hole in the firewall to pass wires through.
Old Mar 22, 2009 | 02:51 PM
1bddelx's Avatar
1bddelx
On my truck the four wires through the firewall to the engine compartment were not connected. I had to connect them under the dash to the switches to make them hot when I turned on my switches. Here is a pic of where they come out.....
Old Mar 22, 2009 | 02:52 PM
1bddelx's Avatar
1bddelx
Agreed, but that's what I used them for
Old Mar 22, 2009 | 02:53 PM
SteveBricks
FTE Emeritus
Same here
Old Mar 22, 2009 | 02:54 PM
GregsSD's Avatar
GregsSD
You should see 4 wires that come out of your wiring harness under the hood, just above your brake booster that are not hooked up to anything.
The other end of the wires is under your dash, just behind the fusebox.
They are called "pass-thru" wires and you can use them for whatever you want so that you dont have to run new wires through the firewall.
Edit- Wow you guys are fast, four replies posted before I got mine typed!!!
