Testing for vacuum leaks
Old Mar 22, 2009 | 07:52 AM
KevinC.'s Avatar
KevinC.
I ran a few searches and turned up nothing. I know you can start the truck and let it idle then run a small amount of propane (unburning of course) over the vacuum lines. If there is a leak the truck will pick up and run much better. Well I'm at home and dont feel like going to buy a handheld propane torch so is there something else that can be used? I have acetylene, but not sure if that will damage motor. Thanks
Old Mar 22, 2009 | 08:12 AM
yoslick's Avatar
yoslick
There ain't much to leak?? no intake manifold/carb like a gasser, have heard a can of WD-40 works good as all it is is diesel fuel with a propane propellant....
Slick!!
Old Mar 22, 2009 | 01:06 PM
DRRXR's Avatar
DRRXR
Simple but effective. Use some flexable 3/8 to 1/4 inch tubing tie wrapped to a dowel rod. Move the dowel around and listen to the other end. Its harder to hear on a diesel but work well on a gasser.
Old Mar 22, 2009 | 01:22 PM
BlueMule's Avatar
BlueMule
That won't work on our trucks, the vacuum is created by a pump, the propane would just follow the line back to the pump and have no effect on rpm's
Old Mar 22, 2009 | 03:06 PM
tjbeggs's Avatar
tjbeggs
Yep what Rodney said. Vacuum isn't created by the engine. No throttle plate to create it. A gauge and hand pump while isolating parts of the system is about the best way I can think of finding the leak.
Old Mar 22, 2009 | 03:09 PM
KevinC.'s Avatar
KevinC.
oooo. Alright, I'll see what I can figure out with it then. Thanks
77f250400
Jun 11, 2010 07:55 AM
mikeyboy1971
Computer Chips & Tuners
Nov 12, 2008 01:20 AM
deadeyetony1
Apr 26, 2005 09:07 PM
CrewCabCOE
Alternative Fuels, Hybrids & Mileage
Apr 3, 2005 01:21 PM
WB9PRG
17
Oct 5, 2003 10:30 PM
