2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
limited slip rear
Old 03-22-2009, 07:29 AM
ron570's Avatar
ron570
ron570 is offline
limited slip rear
Is there a limited slip differential option on the 2008 Expedition, or standard with one of the axle ratios?
Old 03-22-2009, 08:51 AM
clearnetedm's Avatar
clearnetedm
clearnetedm is offline
No the only option is the non-limited-slip 3.73 axle for the EL and 3.31 for standard Expy. Unless your asking aftermarket?
Old 03-22-2009, 09:55 AM
chuck s's Avatar
chuck s
chuck s is offline
I think limited slip interferes with RSC etc.
-- Chuck
Old 03-22-2009, 08:19 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
Yes a LSD is an option but must be ordered with the Limo conversion package. Not sure why you can only get with the limo package.
Old 03-22-2009, 10:00 PM
clearnetedm
Chuck I think your are correct. A mechanic friend actually indicated to me the term (non)limited slip is sometime also referred to a electronic limited slip dif, in Ford's case anyways. Whereas the abs and other systems monitor for slip and apply braking power to the slipping wheel up to 50%. This is what the EXPY uses and I believe is part of the tag AdvancTrac with RSC. I'm not sure why the limo package gets the true limited slip option. Perhaps the limo packaged doesn't come with the AdvancTrac with RSC option and thus needs the limited slip diff??
Old 03-23-2009, 06:11 AM
benshere's Avatar
benshere
benshere is offline
I am curious why they say Limited slip is not compatable with the RSC. If LS keeps one wheel from spinning, then the RSC would not even come into play. Maybe it has to do with the vehicle being corrected in the event of bad swerving by the RSC applying brakes to one side or the other to stop swerving.
I still dont see a problem if the LS is not a clutch type or locker. A Gleason or some "geared" LS would allow one wheel to spin faster/slower with brake apply by RSC.
We looked for a 4X4, couldnt find one at the time we were looking so we settled for a 2X4. I would at least like to have a LS (General term, not a specific type) that would hold better than the RSC.
Anyone got an idea?
Old 03-23-2009, 07:32 AM
montecarlo31
Anyone got an idea?
I noticed your in longwood, I'm up in Tampa and you'll find that down here you'll rarely need 4wd, even on the beaches with the new traction control. I went on a couple of jobsites in 2wd where I would have been done in most cars/trucks but believe it or not the expedition kept on pulling. traction control moaning away.
Old 03-23-2009, 11:30 AM
benshere's Avatar
benshere
benshere is offline
Yea, you are right! Off-road to me is the part between the parking lot and the boat ramp . Kinda would like the extra insurance of LS (TL/locker etc). Been a long since I launched at the ramp on Ft. Desoto state park----if its still there!
Grogtronics
Oil & Lubrication
09-09-2008 08:14 PM
txflyyaker
2004 - 2008 F150
18
05-18-2006 11:52 PM
brncobilly
1978 - 1996 Big Bronco
02-24-2002 09:33 PM
Vaccuum
1999 to 2016 Super Duty
09-28-2001 05:28 PM
proeliator
Offroad & 4x4
08-29-2001 04:55 PM
Quick Reply: limited slip rear
