over boost?
Old Mar 21, 2009 | 10:41 PM
PaYneR's Avatar
PaYneR
over boost?
alright, not to sure on this, money comes first then gauges, probably might swipe a few off some of our trucks if i have to haha, anyways i have stacks, with stock exhaust kinda, did it myself, own a truck shop, and waste gate unplugged, also have 6637 air filter, when i wot in 5th gear all the way to max rpm, about 140ish or so i see a light, the engine light blink on, i shouldn't be getting that much boost stock? i have a 18k mod as well probably around 16k though, but it is like stock? i shouldn't throw a code or get 24-25 psi on my turbo to throw a code stock? any ideas? also after replacing my o rings in the hpop after a failure i tightened and re tightened a few days after my ic pipes and all boots/clamps.
thanks
dan
Old Mar 21, 2009 | 11:18 PM
1996pwrstrk's Avatar
1996pwrstrk
A 140ish what ? What tranny do you have ?
Old Mar 21, 2009 | 11:24 PM
PaYneR's Avatar
PaYneR
6 speed and 140km
Sorry
Dan
Old Mar 21, 2009 | 11:32 PM
1996pwrstrk
Stock you shouldn't get enough boost to defuel plus you would feel it lay down on you, the light would stay on for a little while also. See if you can get your codes read and see what it is.
Old Mar 21, 2009 | 11:38 PM
twags6's Avatar
twags6
It could be defueling a little. My truck has a 6637, unplugged w/g, and the exhaust ends under the bed. With the auto in 3rd gear and the T/C locked, I can hit about 26 psi on a slight incline. The SES light comes on for about a minute and goes back off. Sounds like a jet taking off!
Old Mar 21, 2009 | 11:44 PM
robs01f250's Avatar
robs01f250
well it will set the light at 26psi. and yes it will go off after about a minute or so. But it is setting a soft code that is why the light goes off. Pull the codes and see what code it is throwing and let is know
Old Mar 22, 2009 | 12:05 AM
PaYneR's Avatar
PaYneR
i did, awhile ago at the college after seeing it the first time, all that came up was my 18k mod code, this code i almost cant even catch it blinking sometimes like it flashes so fast, but its usually wot around 140km to 160km...
Old Mar 22, 2009 | 12:10 AM
1996pwrstrk
If you know what the codes are, exactly what answer are you looking for ? I really want to help you but I'm not sure what you want .
Old Mar 22, 2009 | 12:16 AM
PaYneR's Avatar
PaYneR
im just curious of what that engine light is that flashes on and off so quickly when its at wot around 140km the i forget my codes i wrote them down maybe i made a post about them, but ya
Old Mar 22, 2009 | 12:18 AM
robs01f250's Avatar
robs01f250
I would have to say that it is overboosting
Old Mar 22, 2009 | 12:22 AM
PaYneR's Avatar
PaYneR
but how, its stock, other then the mods previously listed? it should not be able to achieve that?
Old Mar 22, 2009 | 12:31 AM
1996pwrstrk
I don't see how a basically stock truck will pull more than 17 to 19 lbs of boost.
Old Mar 22, 2009 | 12:38 AM
PaYneR's Avatar
PaYneR
that's exactly my point, but i have no way to figure out what that blink code is, its not de-fueling either cause it keeps going faster and faster
Old Mar 22, 2009 | 12:58 AM
PaYneR's Avatar
PaYneR
codes that i had picked up awhile back were p1670 not sure what its for? and p1280 is because of my icp 18k mod...
Old Mar 22, 2009 | 10:28 PM
PaYneR's Avatar
PaYneR
im still confused on what it is? i shouldnt be getting a code with pretty much a stock truck...
