over boost?
Old Mar 23, 2009 | 09:21 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by 1996pwrstrk
I don't see how a basically stock truck will pull more than 17 to 19 lbs of boost.
24 psi is very easily done with the wastegate disconnected and an overboost annihilator installed.
Old Mar 23, 2009 | 08:17 PM
PaYneR's Avatar
PaYneR
well wastegate is unplugged but thats it, and it isnt over boost cause that light stays on for a minute? mine blinks like almost hard to catch...
Old Mar 24, 2009 | 08:14 AM
Kwikkordead
The SES light will come on for a lot of reasons, not just overboost.
If you want accurate information, you need to have a scanner connected at the time.
Old Mar 24, 2009 | 08:22 AM
1999SuperDutyStroke's Avatar
1999SuperDutyStroke
An overboost code will not flash it will come on and stay on for between 60 and 120 seconds the flashing sounds like a bad connection or a sensor on its last leg.
Old Mar 24, 2009 | 12:09 PM
PaYneR's Avatar
PaYneR
ok thanks, not sure where i can get a scanner to do that, would the napa scanner work or no
Old Mar 24, 2009 | 11:42 PM
superduty4x4's Avatar
superduty4x4
Probably no, most parts store scanners won't read diesels. If you don't have anyone close with a good scanner, hit up your dealer.
Old Mar 24, 2009 | 11:43 PM
PaYneR's Avatar
PaYneR
how much does it cost at the dealer, i live in a 3000person community 2 hours from a local dealer... though weekends i go to town
Old Mar 24, 2009 | 11:51 PM
superduty4x4
When I had mine done in a similar size town it was around $30 IIRC. Go talk to them, be friendly, and see what they will do. If they are a good dealer they will make you a deal.
Old Mar 24, 2009 | 11:53 PM
superduty4x4
2000 Ford F-350 Diesel Powerstroke! Trip Computer Fix
That's the link you want.
PaYneR's Avatar
PaYneR
alright thanks, ya its just driving me nuts
Old Mar 24, 2009 | 11:56 PM
PaYneR's Avatar
PaYneR
superduty that link has nothing to do with my truck...
Old Mar 24, 2009 | 11:59 PM
superduty4x4
Wrong thread... sorry bro
Old Mar 25, 2009 | 12:00 AM
  #28
PaYneR's Avatar
PaYneR
np lol i was reading up on it then re read it again and again then it said overhead console im like wtf not for me :P thanks though
Old Mar 31, 2009 | 09:37 PM
  #29
PaYneR's Avatar
PaYneR
so today i rigged up a boost gauge and not sure where im going to put my mount for being quite short having a big piller making my blind spot even bigger might be bad, but thats what ill probably do i pulled 22.5 psi of boost in a straight stretch with 18k mod 6637 filter straight piped to dual stacks, stock downpipe... oh and wastegate unplugged, is that normal height? i also rigged it in on that tube from turbo to map, would that be a correct reading?
Old Apr 1, 2009 | 09:55 AM
  #30
superduty4x4
Sounds reasonable.
