Anybody using a 1-WIRE 3G HD ALTERNATOR??
What some places forget to tell you is the one wire alternators don't start charging till you exceed a certain RPM.
Once you exceed that RPM, the alternator will continue to charge though.
Just went through that with a friend that installed one on a 350 Chevy motor and could not get it to charge.
Turned out he was just starting the engine and letting the engine idle so it was not charging.
If I remember right, 3000 RPM was the charge threshold before his started charging.
PowerMaster or something like that was the name on his.
I am running a two wire 150 amp on mine, great addition with all of the electric I use plowing snow at night
In a 1 wire application, you need to get above a certain rpm for the alt to work. In a 3g conversion, there are 3 wires, one of which is "hot in start" which provides the excitation so the alt begins charging immediately. I tried the powermaster in my stang but was not happy with the output at low rpm so I went with a 3g and haven't looked back. I will probably do the 3g mod on my 250 as soon as I have the first indication that the alt is failing.
NotEnoughTrucks2014
12-10-2014 02:27 AM
92blue on uhhhh blue
12-21-2012 01:34 PM
JBronco
1978 - 1996 Big Bronco
10-12-2004 09:46 AM
