Sensitive "twitchy" steering
Old Mar 21, 2009 | 06:00 PM
Bronco1975's Avatar
Bronco1975
This seems to be a new problem with the wifes 00 X 4x4 ltd. No pulling or other steering or alignment issues that i can find.
Very noticeable on the hiway. Almost to the point of a safety concern.
I did a visual the AM, the sway bar bushing "look" ok
Any ideas?
Old Mar 22, 2009 | 09:51 AM
Bronco1975's Avatar
Bronco1975
crickets???
Old Mar 22, 2009 | 10:06 AM
cficare's Avatar
cficare
When you say this is a "new" problem, then the assumption is that the X was not suffering from this problem before now. That means something underneath your X has worn considerably, and is now giving signals that it's about to fail. Jack up the front end and check your ball joints and tie-rod ends. Don't ignore inspecting your leaf spring bushings either. In fact, while you're under there, inspect every mechanical connection associated with your suspension and steering.
Old Mar 22, 2009 | 04:56 PM
Bronco1975's Avatar
Bronco1975
Your assumption is correct. Thanks for the advice. I hadn't considered balljoints.
Old Mar 22, 2009 | 09:00 PM
goldsmje's Avatar
goldsmje
I just cured a steering problem with my 02 Excursion 7.3 PSD. It has 80,000 miles on it and I just had to have the drivers side upper and lower ball joints replaced and the drivers side wheel bearing replaced. Before the repair, I had to keep both hands on the wheel and constantly steer and correct and correct and steer and so on,....after the repairs, it drives like a dream. I love it.
Mtnhermit
Apr 30, 2016 12:57 AM
Mikeman
Apr 3, 2016 10:57 PM
DaytonaTunnel
Jan 19, 2011 01:50 PM
jsfx42007
Feb 22, 2009 01:49 PM
roofmower
Aug 4, 2004 07:40 AM
