Speedometer problem
Old Mar 21, 2009 | 01:57 PM
95 F150 Dude's Avatar
95 F150 Dude
Speedometer problem
Guys,
I recently replaced both my rearend and speedometer cluster. The speedometer is now reading about 7% fast and I don't exactly know how to fix it. I went back through the archives of this forum and found threads that addressed one or the other but not both. I also saw threads about tire size and how to compensate for them but my tires are stock size. My truck is a 95 F150 2WD.
Old Mar 21, 2009 | 04:32 PM
dustybumpers's Avatar
dustybumpers
go to the junk yard where you got the rear, and get the speedometer gear out of the same truck you got the rear from. you have installed a different ratio rear than the one you used to have
Old Mar 21, 2009 | 04:44 PM
95 F150 Dude
Dusty,
There is no gear, it's all electronic. The sensor is in the rearend near the pinion.
Old Mar 21, 2009 | 05:04 PM
dustybumpers
wow your right. I just climbed under my boy's 93 to check it out. I changed the rear in this truck several years ago, with a rear from a 89. I thought the sensor was for the abs.his truck worked out ok. I wonder if there are different sensors for different rears?food for thought. I guess I'm getting old, and not keeping up with all the modern changes.
Old Mar 22, 2009 | 09:44 AM
95 F150 Dude
Anyone else have any suggestions?
Old Mar 22, 2009 | 10:19 AM
FordxFour's Avatar
FordxFour
Have you tried disconnecting the battery for a few minutes. We changed the rear in the neighbors 96' a few years ago and had the same problem. As a last resort we disconnected the battery for a while, and when we hooked it back up the speedometer worked as it should.
Old Mar 24, 2009 | 07:42 AM
95 F150 Dude
Disconnecting the battery did the trick. Thanks FordxFour.
shia1
1978 - 1996 Big Bronco
May 26, 2009 04:32 AM
blinkjs
Mar 25, 2009 09:14 PM
SPL Tech
Apr 2, 2007 05:11 AM
cvlngineer
1997 - 2003 F150
Apr 12, 2004 12:30 PM
CPerry
1997 - 2003 F150
Jun 27, 2003 09:57 PM
