03 Exp EB Please help
Old Mar 21, 2009 | 09:05 AM
99Exp's Avatar
99Exp
Exclamation 03 Exp EB Please help
I have an 03 Exp EB that is making noises and am hoping you guys can help me out. If have it in 2WD there is what sounds like LOUD road noise. If I switch to A4WD the noise goes away. Since it goes away in A4WD it can't be road noise. If I do the switch while driving down the road, there is a loud clunking noise. Gas mileage sucks in A4WD so I would like to be able to drive it in 2WD. Also, if you switch the selector to 4Lo the light doesn't come on anymore. Any ideas would be much appreciated. I am hoping it is an easy fix that my hubby can take care of since this car is a major sore spot for him. If you remember back, this is the one the dealer did as a swap for my 99 that they totalled.
Thanks!!!
Old Mar 21, 2009 | 10:06 PM
ronjeremy6's Avatar
ronjeremy6
dang, you're just not having any luck with this truck are you?
Old Mar 21, 2009 | 11:25 PM
alloro's Avatar
alloro
It sounds like a bearing going bad in the front differential. When you're in 2H, the front axle rotates within the ring gear of the differential. Once you switch out of 2H a vacuum actuator pulls in and locks the axle to the ring gear and starts rotating it with the axle. Since the ring gear and axle are now locked together, the bearing between the two components no longer rolls, hence no noise.
Old Mar 21, 2009 | 11:27 PM
alloro's Avatar
alloro
But does it mechanically shift into 4L and just no light, or does it not shift into 4L at all?
Old Mar 22, 2009 | 06:38 AM
99Exp's Avatar
99Exp
Not sure. I was afraid to try to test it on dry pavement.
Old Mar 22, 2009 | 06:39 AM
99Exp's Avatar
99Exp
Yeah, we hate the thing. Never had any problems with the 99.
Old Mar 22, 2009 | 09:22 AM
Jethrow's Avatar
Jethrow
check u joints
Old Mar 22, 2009 | 12:03 PM
alloro's Avatar
alloro
Knowing whether or not it does will help with the diagnosis.
Old Mar 22, 2009 | 12:26 PM
rconnjr's Avatar
rconnjr
Just wondering, alloro, should the mileage be any different in A4wd as compared to 2wd? I didn't think anything changed unless excess wheel spin was detected at the rear. I going to re-read that long 4wd post again.
Old Mar 22, 2009 | 12:28 PM
99Exp's Avatar
99Exp
Am I hurting it more by driving in A4WD all the time?
Old Mar 22, 2009 | 12:31 PM
rconnjr's Avatar
rconnjr
No, A4wd is fine to drive in. I used to most of the time. It should not affect your mileage (never affected mine) either unless there is some kind of malfunction and it is actually engaging 4wd instead.
Old Mar 22, 2009 | 12:35 PM
rconnjr's Avatar
rconnjr
You can check out this thread for a lot of good info.
https://www.ford-trucks.com/forums/1...ersus-4wd.html
Old Mar 22, 2009 | 04:23 PM
alloro's Avatar
alloro
Some but not much. Even in 2H the front axle turns. The difference when you switch out of 2H to A4WD is that now the carrier assembly in the front differential turns, as well as, the front driveshaft. Turning those does add some load to the engine output, and any additional load will cut into your MPG.
Old Mar 22, 2009 | 05:30 PM
alwaysfords41's Avatar
alwaysfords41
After 119k miles and experiments with A4WD off and on, I've never seen an appreciable difference. Certainly nothing to support "mileage would suck"
Old Mar 22, 2009 | 06:46 PM
alloro's Avatar
alloro
Now if you use straight 4WD instead of 2H or A4WD, then your MPG would drop significantly.
