03 Exp EB Please help
Old Mar 23, 2009 | 04:43 PM
99Exp's Avatar
99Exp
My husband wants to know if you think 4WD is not diengaging?
Old Mar 24, 2009 | 07:40 AM
alwaysfords41's Avatar
alwaysfords41
If 4WD was engaged you wouldn't be driving it - it would bind up when you tried to turn. You never answered the question about 4L that alloro posed.
Old Mar 24, 2009 | 10:03 AM
99Exp's Avatar
99Exp
Is it ok to test it on dry pavemnt?
Old Mar 24, 2009 | 10:05 AM
99Exp's Avatar
99Exp
Originally Posted by alloro
Some but not much. Even in 2H the front axle turns. The difference when you switch out of 2H to A4WD is that now the carrier assembly in the front differential turns, as well as, the front driveshaft. Turning those does add some load to the engine output, and any additional load will cut into your MPG.
MPG dropped down to about 10mpg
Old Mar 25, 2009 | 11:57 AM
jttmoguls's Avatar
jttmoguls
I had a similiar issue with my '03 Expy FX4, i'd be driving down the road and a very loud grinding/roar would come from the front. Mine ended up being the driver's side vaccum-actuated hub. My service dealer told me on the Expys, the vaccum at the hub is always on, it's when you turn it into A4WD or 4HI or 4LO when the vaccum turns off (I guess different from the F150's), and that is what "locks" the front end in. Mine cost about $100 for the hub actuator.
Hope this helps.
Old Mar 25, 2009 | 03:49 PM
99Exp's Avatar
99Exp
Thanks. I'll relay the info to the hubby.
Old Apr 11, 2009 | 09:03 AM
99Exp's Avatar
99Exp
Originally Posted by 99Exp
I have an 03 Exp EB that is making noises and am hoping you guys can help me out. If have it in 2WD there is what sounds like LOUD road noise. If I switch to A4WD the noise goes away. Since it goes away in A4WD it can't be road noise. If I do the switch while driving down the road, there is a loud clunking noise. Gas mileage sucks in A4WD so I would like to be able to drive it in 2WD. Also, if you switch the selector to 4Lo the light doesn't come on anymore. Any ideas would be much appreciated. I am hoping it is an easy fix that my hubby can take care of since this car is a major sore spot for him. If you remember back, this is the one the dealer did as a swap for my 99 that they totalled.
Thanks!!!
Update:
Hubby took it to a repair shop yesterday. The guy says that he thinks it is the motor on the side of the transfer case that pulls it in and out of 4WD, does that make any sense to you guys. From some of your posts it seems like that is supposed to be vacuum acivated????
Old Apr 11, 2009 | 11:28 AM
alloro's Avatar
alloro
The motor he's referring to is the shift motor down on the transfer case and it's electrical, not vacuum. That motor does just what he says it does.
Old Apr 11, 2009 | 12:53 PM
99Exp's Avatar
99Exp
Ok. well he is saying that will do the trick and should cost a couple hundred bucks. WHat do you think??
Old Apr 11, 2009 | 09:12 PM
alloro's Avatar
alloro
The motor goes for about $60 and can be changed in about 20 minutes at home. It's your call.
Old Apr 12, 2009 | 07:03 AM
99Exp's Avatar
99Exp
I just have trust issues with this mechanic. He is a friend of my husband's but when they went out for a road test to hear the noise. They stopped at another shop to get another opinion twice before they came back to tell me what they thought it was.
What fluids do you use to change tthe fluid in the transfer case? He told us to buy some from the local Chevy dealer. Does that make sense to you guys?
Old Apr 13, 2009 | 07:23 AM
alwaysfords41
Use whatever weight is specified, there isn't any magic to it, and it can be had at any parts store.
99Exp
Mar 23, 2012 05:03 AM
99Exp
18
Sep 17, 2009 12:02 PM
99Exp
Nov 24, 2008 11:49 AM
190489
Aug 6, 2008 04:57 PM
bailguy
Jan 24, 2005 11:09 AM
