Head Gasket?
Old Mar 21, 2009 | 04:29 AM
goatz's Avatar
goatz
Head Gasket?
Hey I got a question I just got a really good deal on a 95 crew cab powerstroke F-350, but it has a blown head gasket. what head gaskets should I replace them with? certain brand or use the stock ford ones? I do plan to do head studs too. what about intake gaskets too any certain ones I should use?
Old Mar 21, 2009 | 10:35 AM
tjbeggs's Avatar
tjbeggs
Stock gaskets are the way to go. There are no intake gaskets they just use wacker gray silicone from ford. Don't use other silicone though
Old Mar 21, 2009 | 12:42 PM
goatz's Avatar
goatz
Should I get the Stock Head gaskets from Ford or can I get them from my local autoparts store? (ie felpro, or mr.gasket)
Old Mar 21, 2009 | 01:19 PM
MADVAN's Avatar
MADVAN
You were told its blown? or checked yourself?
I would do some coolant testing before i pulled it apart.
Bill
Old Mar 21, 2009 | 02:46 PM
goatz's Avatar
goatz
I checked the rad and theres oil in there. I haven't chck yet to see if its actually the head gasket that is what is was told. My buddy I got it from says when he turns it over coolant leaks out on passenger side somewhere.
Old Mar 21, 2009 | 05:00 PM
tjbeggs's Avatar
tjbeggs
Lots of other ways for oil to get in the coolant. I will post more later no time now.
Old Mar 21, 2009 | 05:31 PM
cowmilker08's Avatar
cowmilker08
oil cooler?
Old Mar 21, 2009 | 09:52 PM
tjbeggs's Avatar
tjbeggs
oil cooler is most common followed by injector cups.
Old Mar 21, 2009 | 11:37 PM
goatz's Avatar
goatz
Yea what about the coolant leaking out onto the floor from the passenger side? any thought waht that might be
Old Mar 22, 2009 | 01:25 AM
Oversize's Avatar
Oversize
Coolant leaking on the passenger side floor board? Loose fitting on the heater core or broken/ cracked heater core. Its in the dash by the fire wall on the passenger side. Thats what I'd guess based on what you said.
Old Mar 22, 2009 | 03:38 AM
goatz's Avatar
goatz
Sorry I meant to say shop floor. It leaking coolant on the passenger side, in the engine bay on to the shop floor. Gettting truck brought over to my house tomorrow so hopefully will get a chance to check it out.
Old Mar 25, 2009 | 10:41 AM
goatz's Avatar
goatz
OK I got sometime to look at it, there is a what seems to be a plug of some sort on the back of the head on the firewall side oily water is squirting out of there. I don't know what that is.
The water that is coming out is milky brown. So would it be my head gasket or oilcooler or injector cups? Whats the best why to check to see what it is ?
Old Mar 25, 2009 | 11:17 AM
tjbeggs's Avatar
tjbeggs
If it's the big plug in the picture that would point toward injector cups. That plug is the high pressure oil galley that feeds the injectors
Old Mar 25, 2009 | 11:27 AM
goatz's Avatar
goatz
yea its the big plug in the picture. Injector cups hard to change?
Old May 18, 2009 | 02:17 PM
goatz's Avatar
goatz
ok i did i finally had some time to check it out. when I drained the oil there was about 2 litres of coolant in the oil pan, going to pressure check the cooling system and see if its the injector cups today.
