Sponsored by: Real Truck
Noise when braking
Old Mar 20, 2009 | 11:21 PM
roadstar1700's Avatar
roadstar1700
Noise when braking
I have a 2000 F-250 when i press the brakes i can feel a thump in the floor of
the truck.The truck also pulls to the left when braking there is vibration when braking and also while driving.I was leaning towards a bad caliper or stuck caliper on the right side the truck it does drift to the right while gong down the road also or is this maybe a bad ball joint or both?
Old Mar 20, 2009 | 11:44 PM
sprintnut's Avatar
sprintnut
Just to eliminate another possible cause, have your front tires checked. I had this happen to me. You could just rotate the front to back and see if this helps. Caliper/rotor problems could also be causing this.
Good luck,
