coolant temp sensor?
Old Mar 20, 2009 | 12:52 PM
tmbrhg's Avatar
tmbrhg
dads 95 psd auto 2x4 he went to wal mart truck ran fine came out and it would not start. called the local mechanic replaced some parts (dont know what) now mechanic says coolant temp sensor? is reading 265 degrees on a cold engine. he cant figure out where it is located thank you for any help
Old Mar 20, 2009 | 01:20 PM
plowhand's Avatar
plowhand
Playing in the Dirt
1st, fire that mechanic, especially if he can not locate the coolant temp sensor. Coolant temp sensor is located on the top of the water pump next to the neck where the upper radiator hose connects. This has nothing to do with the truck starting.
2nd, does the tach move while cranking? If not replace the TPS.
3rd, if the tach moves, (and even if it does not move) check the under hood fuses, espcially # 22 & # 9. Replace if blown, (if # 22 is blown, diconnect the fuel heater, 2nd plug down on the drivers side of the fuel filter housing).
4th, check the oil level.
5th, let us know what the truck is doing and we will get you back up and running
Old Mar 20, 2009 | 02:20 PM
tmbrhg's Avatar
tmbrhg
thanks plowhand for your reply he checked fuse #22 now hes gonna check #9 and see if the tach is moving. he is helping the well drillers right now but he will get on it a little later. dad is a mechanical genius(old dozers and tractors) but the computers and sensors are a different animal.thanks again
Old Mar 20, 2009 | 10:17 PM
cowmilker08's Avatar
cowmilker08
if the tach isn't monig wouldn't iy be the CPS not the TPS?
Old Mar 21, 2009 | 09:47 PM
plowhand's Avatar
plowhand
Playing in the Dirt
You are correct, it should have been "CPS" (Cam Position Sensor) not "TPS" (Throttle Position Sensor) sorry for the typo, good catch.
Renegade3064
Mar 7, 2022 02:25 AM
SC F250
Jul 15, 2017 03:11 PM
Kennyjothompson
2004 - 2008 F150
Sep 8, 2016 09:03 AM
cory5517
2004 - 2008 F150
Jul 6, 2016 02:53 PM
rterril02
Jun 26, 2016 09:31 AM
